6.2 (L99 LS3) cranks
2 bent rods 2 busted pistons.
The car was an internet purchase, run hard for sure.
The crank rod and main journals are “ok”. A little groovy. It might not polish out. The center main is the worst.
Same casting as 5.3 and 5.7 cranks. But there is a difference. The L99 has gun drilled mains. Anyone notice that? I wonder what the reasoning is.
I’ve heard GM makes a forged crank. Reasonably priced. Anyone know anything about it?
This engine is destined for my C5. I’ll treat it as a big LS1. AFR 210 heads, small cam etc. I didn’t get the 823’s or the intake, so I’ll just reuse my LS1 stuff. Save some good $$$
Ron
The LS7 is a 4 inch stroke forged crankshaft.
The LSA and the LS9 are standard stroke 3.622 forged crankshaft.
HTH!
The engine doesn't need a forged crank, but if mine is out of spec, what the heck.
And I trust GM to get them right.
Thanks 1fastBrick
Ron
The reluctor ring can be changed without issue. The 8 bolt flexplate may interchange with the 6 bolt, just don't have experience with it to know for sure or not.
The C5 has a semi flexplate thing on the engine. With the trans in the rear, I’m not sure if it’s a std auto trans flexplate.
I have also heard that the new LT4 cranks (8 bolt pattern same as LSA) will work and are also forged. The LT4 comes in both a wet and dry sump version.
Andrew
