LSA connecting rods
Old Oct 31, 2018 | 06:02 AM
George Nova's Avatar
Default LSA connecting rods
New to the site. What is the max RPM LSA rods are good to? Engine is an LSX 376 B15. It has a 3.622” stroke and LSX forged dished pistons. Thank you.
Old Oct 31, 2018 | 11:07 AM
How high do you plan on revving to?
Old Oct 31, 2018 | 11:47 AM
I’m currently on the chip (6550 RPM) before the end of the 1/4. I’d like to put valve springs in it and rev it to 7000. Can these rods reliably handle that RPM?
Old Oct 31, 2018 | 12:49 PM
8.Lug's Avatar
You mean rod bolts?
Old Oct 31, 2018 | 02:54 PM
Kfxguy's Avatar
Not sure if this helps any but i have a completely stock bottom end ls1 (weaker rods i presume?) and i turn it to 7000 all the time. stock bolts, pan never been off the engine. 97k miles
Old Oct 31, 2018 | 04:52 PM
That does help. Thanks.
Old Oct 31, 2018 | 05:58 PM
HioSSilver's Avatar
You're good to 8k.....maybe more idk.
Old Nov 4, 2018 | 09:44 AM
Project GatTagO's Avatar
Is this engine boosted?
Andrew
Old Nov 4, 2018 | 11:00 AM
Yes. ProCharger. 15 psi at 6500 RPM.
Old Nov 4, 2018 | 11:31 AM
Personally, I wouldn't push it harder. GM states a redline of 6600 for this engine, and I think it would be smart to respect that, if you want this engine to last. That's just my 2 cents.
Andrew
Old Nov 4, 2018 | 01:03 PM
I hear you. I’m very hesitant to do so. Thank you.
Old Nov 4, 2018 | 09:50 PM
99 Black Bird T/A's Avatar
Given that many stock bottom end LS motors have seen 7,500 rpm to 8,000 rpm and lived when the valve train is set up correctly, I would image the LSX 376 B15 would too.
​​​​​The rod bolts in the older 2000 and back LS motors are weaker than the 01+ rod bolts.
The crate motor would definitely need valve train upgraded and likely a better cam to benefit from ~7,500 rpm.
The stress levels double going from 6,500 to 7,500 rpm roughly.
Luck also plays a factor but a good set up can reduce their risk
Old Nov 5, 2018 | 08:58 AM
Mavn's Avatar
"I MAID THEESE"
What power are you making with that motor with the procharger on 15#?
Old Nov 5, 2018 | 09:52 AM
KCS's Avatar
KCS
Moderator
The problem is that the LSA rods are considerably heavier than the Gen III or the Gen IV rods so the stress on the rod bolts are exponentially higher. I would keep it below the manufacturer’s recomendation.
Old Nov 5, 2018 | 10:37 AM
It was never on the dyno. I’m figuring around 800 at the flywheel.
Old Nov 5, 2018 | 12:28 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Realize a lot of that 6600rpm redline suggestion comes from the 120 gram weight of the intake valves as well.
I'd personally swap rod bolts and let her eat.
Old Nov 5, 2018 | 12:54 PM
Kfxguy's Avatar
So much conflicting info and opinions. If gm states (as written in an above post) that the redline is 6600rpm, what’s 400rpm? Not to mention, I’d like to point out the fact that engine redlines are usually mainly based on what the valvetrain can handle. Op, I would not mess with rod bolts because I think you’ll open a can of worms there. I’d leave the rods as is or lower your rpm requirements for now until you put some stronger rods in it. I don’t think an extra 400 rpm will hurt it. Just my .02
