Lifter suggestions
Old Nov 28, 2018 | 04:49 AM
Joystick's Avatar
Default Lifter suggestions
I’m trying to build a high revving LS (8200-8500 rpm). Short block is a new LS3 block, flat plane 3,0” stroke billet crank, JE pistons (420gram) and R&R rods (6,5” long).
On top I have AFR Mongoose 260 LS3 heads as delivered, exept titanium intake valves, Jesel rocker arms, no pushrods so far.
Comp cam 240/248 @.050 , .647/.647 111+4.
So, fairly good valvetrain stability but need suggestions on lifters and springs. AFR is recommending 7200rpm max, but that’s with the supplied SS intake valves and springs (155lb seat).
This is just an experiment motor and I’m trying to make it work with the parts I have, but I need a set of good lifters and a spring upgrade, so any suggestion apreciated.
Old Nov 28, 2018 | 08:30 AM
Darth_V8r's Avatar
Moderator
johnson short travel lifters, and go BIG on the pushrods. 3/8 x .125 series 5 manton
Old Nov 28, 2018 | 08:42 AM
big hammer's Avatar
Im running pac 1208x spring over 8000 but I have a Cam Motion solid Cam and 7/16 pushrods
I’d go solid at this point if you can and gear up for closer to 9000 rpm
Old Nov 28, 2018 | 03:16 PM
ColeGTO's Avatar
Walk right past the Hydraulic Roller booth and stop at the Solid Roller guys place for this application. Stick with 3/8 heavy wall or 7/16 pushrods if you can fit them. I'd talk to a spring manufacturer for thier recommendation, but have the weights of ALL your valvetrain components before you dial the phone.
You'll be happier with the RPM capability of a SR setup and have less to worry about in the end.
I'm not convinced that a 240/248 cam would go to 9000 RPM though. 8000-8200 I think is possible.
My daily driver is a LS3 with stock 3.622" stroke, LSX-LS7 heads (270cc) and it has a similar cam (236/246 @ .050", .648"/.648" 110 +1) and it's pretty much done at 7200. I think the LS7 lifters are likely the cause. But I'm OK with that because I feel bad turning the stock crank any more RPM than that.
Old Nov 29, 2018 | 01:24 PM
Joystick's Avatar
Thanks guys, deep down I kind of figured a SR is the way to go, just trying to use the parts I have.
So, going Solid iso HR, who is the best to grind a cam for my application?
I have connections with Comp.
Suggestions?
Old Nov 29, 2018 | 01:59 PM
L79racer's Avatar
I run a cam motion LLSR with pac 1238x springs with manton seies 5 3/8 to11/32x120 push rods. Spining it just over 8000.
Old Nov 29, 2018 | 09:58 PM
Darth_V8r's Avatar
Moderator
Suggestions?
Cam motion sells the LLSR package. Ask for Steve.
Old Nov 30, 2018 | 06:36 AM
Not to be argumentative here, but I’m running a Comp solid roller and it’s quiet. In fact it’s the quietest LS valvetrain I’ve ever heard. Lash is set at .003 cold. If you have connections at Comp, give them a try. I just got a Comp cam cut for a different build, spec’ed by Tony Mamo, and it’s got their new polished finish on it. Impressive. A solid roller will require a different spring setup, but that’s the nature of the beast.
I like what your doing here. Is this intended for a street or race application? What vehicle is it going in?
Old Nov 30, 2018 | 07:14 AM
Joystick's Avatar
I’m just finishing up a Superlite SL-C build, it will be 90/10 street/track. For now it’s just a stock LS3 with a Comp HR 54-469-11 and AFR Mongoose 260 heads. Stock LS3intake.
About two years ago I stumbled on this flat plane crank with rods, pistons and a HR cam and I think the sound of a flat plane will be perfect to this kind of car.
I’m not looking for any big number HP, more the sound and high rev. My present LS3 will most likely produce more power than the flat plane.
Anyway, I don’t mind lash adjustment couple of times each summer (valve cover comes off easy) so I’ll call Comp for a solid.
Thanks guys, you just confirmed my thoughts.
Old Nov 30, 2018 | 09:17 AM
62nalide's Avatar
Johnson 2116LSR
Old Nov 30, 2018 | 01:41 PM
I love a SLC!! A perfect candidate for what your wanting to do here. I’d love some pics. Do you have a build thread somewhere?
Old Dec 3, 2018 | 12:56 PM
Joystick's Avatar
https://www.gt40s.com/threads/scandi...d.51991/page-6
I’m about 10 months in the build, aiming for inspection this spring
Old Dec 12, 2018 | 02:37 PM
NSFW's Avatar
The 3.0" stroke crank for this project is going to flow roughly 20% less air at the same RPM as a 3.6" stroke, which means roughly 20% higher RPM before the same airflow restrictions come into play. For example I'd expect your setup to be "pretty much done" at 8600 rather than 7200 if you swapped to a 3.0 crank (and a suitable intake runner length, etc). So an 8500 target seems pretty reasonable for this project.
Of course he'll have a different cam, and none of these relationships are truly linear, but it's not a bad way to get a rough estimate.
Old Dec 13, 2018 | 05:32 PM
00pooterSS's Avatar
I looked at the build thread a little, that looks like a ton of fun and the build is looking really nice.
And I would definitely use cam motion and go solid rollers.
Old Dec 16, 2018 | 04:29 PM
foxsl's Avatar
cam motion for the win always
