Is this normal?
Old Jan 13, 2019 | 04:45 PM
TurboTim's Avatar
Default Is this normal?
The bearings don't meet up evenly? I am running Lunati rods and 807xpnc bearings.
Lunati rod
Old Jan 13, 2019 | 04:46 PM
TurboTim's Avatar
I am also putting this angled side toward the fillet or whatever its called part of the crank, is this correct?
Old Jan 13, 2019 | 05:03 PM
No, that is NOT normal. You have something switched around.
Old Jan 13, 2019 | 05:23 PM
TurboTim's Avatar
There was 2 packages of 8 and I am wondering if they were different. They were not marked anything different but maybe they were?
Old Jan 13, 2019 | 05:28 PM
There should be eight pair that will fit the rods as they should. Do a little more mixing and matching until they fit correctly. You might have either two upper or two cap bearings in the pic.
Old Jan 13, 2019 | 07:51 PM
Look on the back of the bearing. There with the stamping, you will see a “L” and a “U”, meaning upper and lower. You’ve likely got something doubled up.
Old Jan 14, 2019 | 04:52 AM
TurboTim's Avatar
How about the rod chamfer, does that go towards crankshaft or towards another rod?
Old Jan 14, 2019 | 06:57 AM
Chamfer goes toward crank, placing larger rod cheeks toward each other for more surface area to rub against inwardly. Not a big deal with a Oem LS crank, since the crank throws don’t have a radius. That’s just how I do it.
Old Jan 14, 2019 | 05:47 PM
KW Baraka's Avatar
.........….That’s just how I do it.
Do it as he does it. ^^^^^^^^^
KW
