Help pushrod length
Old Jan 27, 2019 | 08:19 PM
Cbmaddox33's Avatar
Question Help pushrod length
This is my first motor I’ve ever built and I have a 5.3 with comp cam stage 3 turbo cam with ls7 lifters and ls9 head gaskets with 706 heads , if I measured everything correctly I need a 7.435 push rod . Does this sound right ? And where can I buy a push rod in this length?
Old Jan 27, 2019 | 08:49 PM
Tell us how you’ve determined this length so we can establish where you are. LS7 lifters have a rather large preload window.
Old Jan 27, 2019 | 09:12 PM
Cbmaddox33's Avatar
I put a push rod in my exhaust valve and rotated the motor until the push rod started to come up. I then put my push rod checker in the intake valve and adjusted it until I had no tap or movement in the rocker from side to side it up and down and made sure the rocker seated correctly which came out to 7.350 and I added .085 for pre load
Old Jan 27, 2019 | 10:40 PM
Cbmaddox33's Avatar
ANYONES help would be greatly appreciated!
Old Jan 28, 2019 | 07:01 AM
I PM’d you back sir. I think your gonna be fine.
Old Jan 28, 2019 | 07:20 AM
cmysix's Avatar
this stuff is maddening! you went for .85 preload LS7 lifters have a range of .200, Tick says he likes to go .100 on ls7 lifters, Try POWELL MACHINE they advertise a .005 tolerance between rods all the reading I have done says even the "name brand " can be off .015 or more, probably easier to find .450 or .425 and I think you'll be good!
Old Jan 28, 2019 | 08:30 AM
RB04Av's Avatar
I'd go with 7.450 if I had come up with those #.
Remember, metal doesn't grow as it ages, it only wears.
I'd also strongly suggest measuring more than one cyl. I'd suggest the 4 at the corners (1 2 7 8), at the very least.
Old Jan 28, 2019 | 09:53 AM
Cbmaddox33's Avatar
Okay I appreciate all yalls replies!
Old Jan 28, 2019 | 01:47 PM
patSS/00's Avatar
You can find 7.440 (do an internet search), not a commonly available size, I just got a set. Not posting a link since it's not a sponsor. Also the ones I got are not chromoly.
