2020 6.6L gas engine for 2500HD
Saw a lot of issues on the Internet mentioned for whatever that's worth.
Ford and quality low maintenance engine design usually go together about as well as ice cream coated anchovies & wasabi oysters do with chocolate chip pecan pancakes for breakfast. I've met many Ford owners burned by the mod motor spark plug fiasco, several burned by the mod motor timing chain issues and several burned by the Ford v6 front & rear timing chain issues. Maybe this new pushrod 7.3 V8 will mark a turning point and a clean slate for Ford.
The two people I know that had the issue both had LS7's with big cams. Stock stuff works just fine imo. I was merely poking fun at Ford because Ford lol. That said, I'd much rather have their 7.3L than GM's 6.6L, if its not a turd like the V10 that makes 420ft/lb
That new Ford LS motor looks pretty simple with no direct injection. That motor is going to be the new LS swap motor in the future being so simple and pretty compact for a 7.3. I hate to say it but that Ford motor is going to be more attractive to fleets than the GM motor.
