Ls2 vs Ls3
So for an all forged boosted build with a 24t reluctor is there any significant difference in strength between the blocks?
Also if using a cathedral top end with a wire driven throttle body on either short block the swap into an ls1 vehicle is the same regardless which block I choose correct? Just the cam sensor location, ls2 valley cover, and moving the knock sensors to the side of the block are required for either block when using cathedral heads and ls6 intake correct?
Given the bore is .065 bigger with the same thickness liner in an LS3, I think the block is very slightly weaker. I think Race Engine Development posted some details on block strength but I can't find the thread. If I recall correctly Steve at RED said LS2 was slight stronger.
This maybe of interest to read.
YB LS2 vs LS3 block discussion
LS1TECH - block strength
