Valve spring questions.
I purchased a set of 799 heads awhile back for my LS1 with dual springs already installed. I believe the guy said they are either PAC springs or Tooley springs good for .650 lift.
I am now taking those springs off and putting them on my 823 heads for the LS3 I'm building, and wondering if I should check installed height or just run them? They have the seats with titanium retainers, from what
I read his springs are plug and play with a stock LS1 head?
Want to make sure before I install them. The cam I'm running has around .621 of lift on the intake side, and .605 on exhaust.
Moderator
https://www.summitracing.com/parts/r...iABEgL7bvD_BwE
I finally got ahold of the guy that sold me the heads 2 years ago. They're tooleys. 660 platinum springs with titanium retainers. They were ran on a turbo car. They look good but what the hell do I know. I might just buy some new ones. On his site he says they're drop in and go on the LS heads (stock)
Get new springs, you hate to find out otherwise that you should have.
All springs will end up dropping spring pressure in time, but you want to test them by compressing them according to a previously measured compression height on a spring pressure tester in a vise.
Compare the numbers to see what you have... let us know what you find and you will get a recommendation.
