Help me build the new 418 LS3
* Are we positive I won't have any undesirable side effects from 12.5:1 compression on 92/93 octane? The builder is worried that I'll run into limitations with advance using that much compression. I think I'm going to shoot between 11.5-12 for peace of mind.
* We bought springs before we knew what the chosen cam will want for seat pressure, is that a concern? Should we just aim to have the installed height at the advertised 1.800"? Do we need to 'shim to within .00X0 of coil bind'?
* I spoke with CamMotion again, they say their advertised duration's are 55* higher than their .050 duration's. For DCR, how do I estimate advertised IVC based upon .050 IVC? Am I calculating this right on this example cam?
.050
IVO=5.5, IVC = 43.5, EVO = 57, EVC = 7
229/244 duration, LCA = 112, ICL = 109 ECL = 115, overlap 12.5*, slight intake bias
.004/.006, assuming 55* ramp rate
Intake duration = 229 + 55 = 284
IVO = (284/2)-109) = 33
IVC = (-33+284)-180 = 71
So I would use 71 for my seat IVC for calculating DCR? CamMotion thought I'd build a lot of low end torque with this cam (which is what I want beginning around 3500-4000RPM), but thought it'd stop climbing and flatline after about 6000RPM. Without sacrificing street manners and torque above 3500RPM, are there any minor valve event changes I can make that would allow it continue to climb a little longer past 6000RPM?
You stated in your original post that you wanted strong low RPM torque in the 3500-4000 RPM range and a powerband that carries well past 6000 RPM. In general you must make some compromises between low RPM power and high RPM power when choosing a camshaft in single cam applications.
Ideally, you would pick a camshaft that is a good compromise between lower RPM torque and upper RPM performance. In a 418 stroker, this would look something like a 234/244 on 115.5+4.5 with about .621"/.604" lift. This would have valve events like this:
IVO 6
IVC 48
EVO 62
EVC 2
This camshaft would have a defined, prominent lope at idle, but still have very good drivability. It will have some bucking at low RPM at part throttle in a stick shift car, but much less than an aggressive camshaft would.
On the compression topic, my builds and my customers builds have been successful repeatedly with compression ratios in the 11.5:1 area.
That cam is 232/242-114+4 or
IVO 6
IVC 46
EVO 59
EVC 3
If you are not going to rev much just install them. If you plan to rev, shim them.
Run good pushrods. 11/32 minimum.
IVO 6
IVC 46
EVO 59
EVC 3
Without advance notice, the builder asked the machine shop to shim the springs 30 thousandths for a bit more seat pressure. The builders valve spring tester indicated about 140lbs at 1.8" height when we tested a spring new out of the box, although it's advertised as 150lbs on the seat. I asked them to see if they can measure what it is shimmed before completing the head assembly.
They said they followed the directions given to me by Al at Manton... confirm valve is on the base circle, torque rocker to 22ft-lbs, extend adjustable checker to 0 lash, then measure overall length of checker with a digital caliper. They come up with all intake push rods at 7.415" and all exhaust push rods at 7.400". I find that uncannily similar to the OEM 7.400" length.They did measure the base circle and said that the intake & exhaust were slightly different, and that was the reason for the different push rod length difference.
* the 823 head had a 65.5cc chamber (stock chamber is ~70cc-65.5cc=4.5cc * 0.0055in/cc = ~0.025" milled)
* the head gasket is about 0.010-0.015 thinner
* we took 0,013 off the deck
* Randy at Johnson said that this lifter generally needs about a .190" longer push rod
* perhaps a difference base circle than stock
Al said to send him the numbers in a spreadsheet and he'd see if they were all close enough to use a common length with this lifter. The numbers don't seem to add up with the change in the stacked height... do I just go with what they measured and add the .0035" preload to the lengths?
1) I was originally told the old valves in the used head were sunken too far, and they said we could clean up the valves and do a valve job or get all new valves and a VJ. So I bought all new valves and they sent the head to a machine shop for a valve job and for the machine shop to install the springs. The springs were supposed to have been shimmed .030 to increase seat pressure at 1.8" installed height. My shop told the machine shop to not replace the seats due to time and cost concerns (although I was not directly consulted on this decision). It's possible this valve is sunken a little further, which would raise the stem tip, and reduce the push rod height. It's also possible that due to the higher tip, the seat pressure is not correct if the machine shop didn't measure all heights. I suppose if the valve is sunken a bit further, that would cause that chamber to be a bit larger as well.
2) Perhaps the new rocker, or a new valve that is slightly longer, or a a lifter that has bled down a bit, but I think those are less likely scenarios.
I've asked my shop to verify the installed height on the #2 exhaust spring and/or the height of the stem tip compared to another exhaust valve on the same head. If the installed height is wrong, correct it. That won't fix the need for a shorter push rod on that valve though.
#1 exhaust .020+7.4910=7.5100
#2 exhaust .018+7.4880=7.5060
#7 exhaust .013+7.5130=7.5060
Much happier now!
Problem didn't exist prior to it being towed to the shop, and I provided a new OEM oil pressure sender for them to install, and they said they used the new sender. Ideas?
* The shop labor to measure the push rod lengths should be reduced or eliminated since they came up with incorrect lengths, short by about .100". I provided written instructions to them from Manton on how to come up with the correct lengths before they started the process. I spent 5-6 hours doing it myself at their shop for the final numbers. Or, give me a partial credit against my time to obtain the proper lengths.
* The block was sent to a machine shop to be bored to be compatible with the shops desired piston size, and for the block to be cleaned. After the block was returned, the rotating assembly was mocked up and deck clearance was measured, it was sent back to the machine shop for the deck to be milled to 0 deck. After the shop installed the rotating assembly again, they determined that their staff incorrectly diagnosed the rod bolt clearance as adequate. They needed to disassemble, massage the block, clean the block again, and reassemble. If that the clearance problem had been realized prior to the last time it was sent to the machine shop, the additional disassembly/reassembly/cleaning would not have had to be done. I'm fine with paying for the labor to massage the block, but this was done out of order and I should only pay for the time to massage the block, not to disassemble/reassemble/clean the block yet again.
* Valve job is supposed to be included in the initial quote. Shop owner had the machine shop perform the valve job, and add .030" shim to increase seat pressure without my prior approval (taking it from 140lbs to 150lbs). This information wasn't given to me until after the work had been done. I don't feel as I should pay extra for this since it wasn't pre-approved.
*Dash oil pressure gauge reporting high PSI (pegged above 80) and high when key on, engine off (40) after engine reinstall with a new sender, that issue was definitely not occurring with the old sender prior to teardown. I seem to recall being told that the old sender was damaged during teardown. My opinion is that if a another new OEM sender doesn't fix the issue, then the problem was caused after the vehicle was loaded onto the tow truck and I shouldn't have to pay for that labor to fix this issue. When I was there yesterday, they had the passenger kick panel removed like they were checking wires.
Appreciate any feedback.
IVO 6
IVC 46
EVO 59
EVC 3
Too biased to the intake side which will sacrifice your top end.
It's not taking advantage of the high compression or the cubes you have either/
Something like a 236/250 115 LSA+3 would work better and still drive pretty good in a 418 CID with 13 degrees of overlap.
IVO 6
IVC 50
EVO 63
EVC 7
