Low Lash solid roller ls3 build
Old Apr 11, 2019 | 05:56 PM
big hammer's Avatar
Mast Med bore ls3’s are nasty good
Old Apr 11, 2019 | 08:16 PM
zboy2012's Avatar
How long did it take to get yours after you ordered? Did you order through a vendor or them?
Old Apr 11, 2019 | 08:37 PM
Smokey B's Avatar
Trick is to add more compression & rpm for the cheaper head but don't tell it.
Don't forget Liberty (maker of 1 of the guys known, 4 got the name: spm... ) 11degree as cast Ls3 heads are..400ea. FED / port work $900-1200
Too many options for a budget.....
big hammer's Avatar
wasnt long. Ordered them through Phteve at Cam motion
Old Apr 11, 2019 | 09:41 PM
zboy2012's Avatar
Just curious, which valves did you run?
Old Apr 11, 2019 | 09:44 PM
zboy2012's Avatar
Went and picked the transmission up the lvl 5 from RPM.
Old Apr 11, 2019 | 10:52 PM
Darth_V8r's Avatar
Moderator
He ran 8 intake valves and 8 exhaust valves.
Old Apr 11, 2019 | 11:04 PM
Smokey B's Avatar
You can get a few different valves....ferrera or manley, del west, etc. Went with manley hollows. Choose based on rpm and if a power adder is being used.
 Michael S. Palmer
Old Apr 11, 2019 | 11:30 PM
zboy2012's Avatar
🤣😂. Guess I should’ve been more specific. It’s just if I do decide on getting them the problem was going back and fourth between the solild/solid or hollowstem/solid options haha
Old Apr 11, 2019 | 11:31 PM
zboy2012's Avatar
There’s no power adder... the setup should peak around 7400-7500 so I’ll be shifting around 7800
Old Apr 12, 2019 | 12:17 AM
Darth_V8r's Avatar
Moderator
My preference is for solid valves, especially if you plan to run higher spring pressures. With solid lifters you can get away with a lot.
I would run titanium intake and stainless exhaust. Maybe even inconel
Old Apr 12, 2019 | 12:22 AM
  #32
zboy2012's Avatar
Seen the titanium option also. Didn’t know if was really worth the extra cost over the others or not and always heard stuff about running them on a street driven vehicle. Good to know.
Old Apr 12, 2019 | 01:10 AM
  #33
Smokey B's Avatar
Hollows and good springs... A heavier valve needs more spring press to control. No matter hyd or solid roller. ask a ferrera rep or Pac rep....as said @ 730 lift with 7400 - 7500 peak same FED ported factory ls3 heads. Ask Steven or a rep mentioned.
Ti valves run $1200 new...... Spec'ed a 6.200 long hollow stem for a Ls raised runner design to bypass $1300 Ti valves ($4k heads with valves & springs). Hmmmm F10 heads.
Old Apr 12, 2019 | 01:25 AM
  #34
Smokey B's Avatar
I'll leave u with this i could have got the 800+ looked for with factory ls3 heads and not make one. wouldn't do it no other way even if i had to do it all over again. What was learned isn't on any forum all laid out in a thread. I know of guys spending well over 5k in heads and intake yet not out perform a similar cheaper set up. Fact.
When guys start understanding CSA for a given rpm and engine size (theres a formula on wallace calculator, my ls7 heads match the csa for the engine size and rpm 100%. How many can say this with cnc or ported heads?) They maybe on to something. Guy's building basically a race prepared street engine with Generic numbers like it has 258cc or this head works but don't know why besides it has a better valve angle. Funny. No matter what heads are picked, to maximize them they need to match rpm & cid with the head CSA. Some pay twice with a cnc head then another fee for matching the CSA. Funny.
Old Apr 13, 2019 | 12:25 PM
  #35
AINT SKEERED's Avatar
I have stainless 2.165 ferrera valve with pac1209x springs on my 427. No sign of valve float to 8000 rpm
Old Apr 14, 2019 | 02:48 AM
  #36
zboy2012's Avatar
Awesome, looks like I’ll stick with them then.
Old Apr 14, 2019 | 05:18 PM
  #37
mine were shimmed to leave .060 before coil bind. Very stable with hella terra rocker arms. I do advise to get jesel rockers though as adjustable yet 6653 rockers are a nightmare for valve covers
Old Apr 14, 2019 | 05:47 PM
  #38
Smokey B's Avatar
Comp cams pro magnum adjustable steel rockers 1.8 or 1.7 ratio, Pro Form valve covers around $800 total for both.. Pac 1238x springs / manley 2.165 hollow stem valves 1.60 ss exh. valves....reference with the same heads and porter used.
Old Apr 14, 2019 | 06:14 PM
  #39
zboy2012's Avatar
Ya I’ll be running either and adjustable set if jesels or crowers. Didn’t want to try a. Run a factory rocker on a LLSR setup. I know it can be done I just didn’t want to try it lol.
Old Apr 14, 2019 | 06:16 PM
  #40
zboy2012's Avatar
I’ve got a buddy who is running the pro magnums. So far he likes them. Would like to see more about them before I ever purchase them. If I ever run them it’ll be on another build in the future for my wife’s car
