.0032 Main Bearing Clearance?
Piston to wall - .005"
Rod bearing clearance - .0021"
Main bearing clearance - .0032"
At first glance, the main bearing clearance seemed pretty large? Just wanted to get some thoughts.
Also, always wondered, how much do bearing clearances have to open up to see a change in oil pressure? For example: if I went from a .0025 to a .0032 main bearing clearance, would that be noticeable on oil pressure?
The issue with that much spread is you've got rod bearings wanting a 30 grade and mains wanting a 50 grade. You either run a 15w-50 or 20w-50 and risk overheating / spalling the rod bearings or run a 30 grade and risk insufficient oil wedge in the mains. I'd want to get the mains down to around .0024". Unless this engine is pushing 1,000+hp, you'll get better load carrying capacity with clearances closer to .002" anyway.
Said he had no issue whatsoever with them. I'm running Thompsons recommended Moroso pump, and he also recommended 20W50 for the oil weight.
Motor was build for 150-200 shot of nitrous. 416 LS3.
Thompson, from what I've read, has a sterling reputation around here, so I can't imagine they'd let something leave, that was knowingly going to be a problem.
I'd try to minimize friction and aeration as much as possible. A PAO/POE synthetic with loads of friction modifier would be best. Red Line HP 15w-50, Driven FR50, and Amsoil Signature Series 5w-50 would top that list.
KCS, the pump TMS sent with this motor is the Moroso 22120. It does say it’s a high volume pump.
What would you guess oil pressure would be with the 20w50 VR 1 that Thompson recommends?
And as it was mentioned that the motor would have to live its life on 50w, is there anything inherently wrong with that? Again, I’m trying to give Thompson the benefit of the doubt here, I can’t find any negative press with them, but nor do I have any idea why the motor was set up this way...
