Upgrading LH6
Old May 31, 2019 | 02:47 PM
Aaron1017's Avatar
Default Upgrading LH6
Picked up a cheap 2005 LH6 pullout to swap into a RX-8 for a weekend car. Currently stripping down the engine for a cam and DoD delete. Should be fun in a 3050 lb car with T56 and 4.1 rear end ratio.
I'd like to bump the compression up a little bit from the stock 9.9:1. Its been about 10 years since building an engine and just getting back into the swing of things.
How much can I mill the heads and be safe? Leaning towards just .010
Worried about the duration because its a large camshaft.
Buying my pushrods last... still trying to find my pushrod checker.
Camshaft and spring kit: https://www.summitracing.com/parts/sum-8708-1ds (231/242 600 lift)
Lifters: https://www.summitracing.com/parts/sum-ht214
Head Gasket: https://www.summitracing.com/parts/fel-26191pt (0.048")
Old May 31, 2019 | 02:49 PM
MechMan1's Avatar
I thought I heard .030 was the max safely but not 100% on that. maybe someone who know more will chime in.
Old May 31, 2019 | 04:21 PM
DualQuadDave's Avatar
.030 is fine, just degree the cam in and check p/v clearance. Might even go .040 if all checks out. Need to watch the intake clearance, some intakes will work out with the head chop and some might give you a headache going back on. Depends.
