6.0 build help!
Old Jun 6, 2019 | 05:48 PM
jwillie128's Avatar
Default 6.0 build help!
Hi everyone, I’m new here. I’ve been doing lots of research and I can’t seem to figure out an answer to my problem. My buddy and I swapped his truck (2000 GMC Sierra) from a 4.8 to a Gen 4 6.0 with milled 243 heads. The heads are milled .040. The bottom end is stock. We’re using the lingenfelter box to run the 58x reluctor wheel.
The problem were having is a ticking noise. It’s not the lifters, bc they’re brand new and we’ve swapped them out already. We’ve tried multiple different length pushrods (7.250, 7.300, 7.394) and nothing will make it quieter. It runs great, with no issues which is part of the reason I’m puzzled. No matter what we change the ticking won’t go away.
Any help or or advice would be greatly appreciated, Thanks!
EDIT! I’ve attached a video of the noise
Old Jun 6, 2019 | 05:50 PM
Tuskyz28's Avatar
What oil ?
Old Jun 6, 2019 | 05:51 PM
jwillie128's Avatar
Originally Posted by Tuskyz28
What oil ?
15w-40
Old Jun 6, 2019 | 05:53 PM
Tuskyz28's Avatar
Originally Posted by jwillie128
15w-40
What brand ? All oil brands are not the same.
Old Jun 6, 2019 | 05:58 PM
jwillie128's Avatar
My bad, it’s Eco Power synthetic blend. It’s a bulk oil I bought. Could it be too thick of an oil?
Old Jun 6, 2019 | 07:15 PM
rkupon1's Avatar
Tried simplier process of elimination yet? Remove serpentine belt for a few seconds...it ll rule out all pulleys and idlers, etc
Old Jun 6, 2019 | 07:39 PM
jwillie128's Avatar
We’ll definitely try that tomorrow. Gonna try tightening the manifolds and y pipe, maybe an exhaust leak?
Old Jun 6, 2019 | 07:55 PM
andrewss's Avatar
Kinda sounds like an exhaust leak Sometimes you can hear noises better from under the engine..
Old Jun 6, 2019 | 10:48 PM
jwillie128's Avatar
Confirmed tonight that it’s not an exhaust leak and not any of the pulleys. The noise sounds like it’s farther to the front of the motor but it’s hard to tell
Old Jun 8, 2019 | 09:27 PM
01CamaroSSTx's Avatar
Sounds valve train related to me.
Old Jun 9, 2019 | 12:50 AM
bortous's Avatar
Sounds valvetrain related to me too.
Old Jun 9, 2019 | 04:47 PM
Project GatTagO's Avatar
That can easily be injector noise.
Andrew
Old Jun 10, 2019 | 11:54 AM
jwillie128's Avatar
That’s what I’m thinking. I’m gonna try shimming the rocker pedestal .010 at a time and see if that makes any difference.
Andrew
Yeah but all the injectors are brand new. However one of them could have failed
Old Jun 10, 2019 | 12:21 PM
Just because they are new, doesn't mean they don't make noise. That's the reason many LS engines had the factor engine covers, to cut down on noise.
Old Jun 10, 2019 | 01:16 PM
Every injected engine I have heard makes SOME injector noise. Just the lightest clickety.....
Old Jun 10, 2019 | 03:29 PM
jwillie128's Avatar
Yeah I know some noise is normal but it definitely shouldn’t be this loud. I may also go into HP Tuners and turn them off one by one to see if that affects the noise
Old Jun 12, 2019 | 02:38 PM
Ls7colorado's Avatar
seriously sounds like a exhaust leak, how did you rule it out?
take a water hose and spray around the manifolds/headers (without it being to hot of course)
Loose spark plug?
Old Jun 12, 2019 | 04:55 PM
Stampede4ever's Avatar
Sounds like exhaust leak,. Check it with a smoke machine, easy to make.
Stampede
Old Jun 12, 2019 | 07:36 PM
Utinator's Avatar
I would check the valve covers. If you have aftermarket rocker arms in there, then they are probably hitting inside the valve covers.
Old Jun 12, 2019 | 08:55 PM
Once again it sounds valvetrain related to me and ↑↑↑ the rocker making contact with the valve cover is a possibility and so is the rocker arm making contact with an aftermarket rocker arm bolt a possibility.
