Reliable Daily Driver: 4 inch stroke LS2
Luv..less rpm 4 hp = stroke...go with i wanna b different...get F'ed...388 runs 10.1's 418 runs 9.8's tfs heads same style car....pump gas & hyd roller...
Yeah your rpm just got F'ed with Luv...
Hi...real HNIC in the building...sorry to call BS. We talking street...no SR involved.
99 i'm off your thread..best of.....u no...
You're welcome to post car and engine related comments.
It is just stoned rambling to me.
It's a shame as Smokey was making good points in other threads yesterday.
The term that I put in bold, it's absolutely offensive. Can't let that slide, have to say that's not cool, don't post that sort of stuff. To say nothing is to condon the use of the phrase,
Head N-word In Charge - radioactive offensive in my opinion. It's a word with a horrible history and context in America. I don't know about else where in the world.
He was referring to himself as a HNIC.
Nothing has changed with racism.
It's still rampant everywhere.
Using of the term is the issue. It has no place being used regardless of who he was referring too. The term is offensive.
As long as he was not actually being racist and saying derogatory things then yes I would draw the line.
I don't like racism either.
Smokey if you are reading this, process this information properly.
While kicking this all build around, .020 over is the stated max for a LS2 but is there really much risk going .030 over? Or maybe a better way to say it is how often are the liners straight enough without shift to go 4.030? Will sonic check show for sure?
My block has to go .010 over to clean up if doing the stroker. I've read of a few rare LS2's going to 4.065 even.
What's y'alls experience and impression?
It's a common thing to do.
You can bore them more but then you risk strength and that's something I would do.
.030 is the max safe overbore.
Those TFS heads seem make less power than GM LS3 heads.
I won't touch any aftermarket LS3 head.
I would either use an LS7 or a high end cathedral
If you can get a block that will properly support the ls3 platform I'd do that. The ls3 and ls7 heads are very efficient in terms of port design and the short side walks all over the cathedrals.
Plus fitting a set of higher ratio rockers helps too.
This shrouding is very exaggerated.
You would be hard pressed to tell the difference.
I am using a new block for my next build.
I will either use an ls9 or dart aluminium block.
Being on a larger bore might make a few more ponies vs a 4.030 but the difference isn't huge.
However i will ask my builder this question tomorrow.
He will be able to give me facts.
I have no data myself but by engine builder has been building LS's since the late 1990's when they were first released.
He has done hundreds of these over the years and is the primary engine he builds.
I will find out and post his response here.
