Reliable Daily Driver: 4 inch stroke LS2
4.125" is .060" larger than the 4.065" bore... half of that is .030" (radius) in case you're wondering how I came up with that (and assuming the head remains centered).
The 4.185" bore I'm aiming for provides .060" of valve to wall clearance above an LS3 bore.
The difference between a 4.03" and 4.065" bore is .0175" so you can see how that helps. Nearly doubling it would help even more.
I don't know how that affects the manifold and such with clearance. But .030" isn't a lot.
Again, they are designed for big block Chevy, but fit LS applications exact. If shrouding is an issue, this is an easy fix. Moves the exhaust valve over toward the wall like an ls7 head also, but exhaust shrouding isn’t an issue since piston is forcing pressure outward. I’ve used these and it works well. No issues with manifold alignment upstairs either. There is more than .030” play in the manifold bolt sleeves. Run it by your builder.
make sure to check radial clearance on your pistons valve pockets with modeling clay, while checking ptv, if your running pockets. I cut my own pockets, so I had no problems.
Decided to go 408 LS2 after getting a decent deal on a slightly used unblemished 4 inch Callies CompStar Crank. The build is still a long ways off but the crank is on the way.
I can't find the exhaust flow numbers this morning.. Lol..Mamo ported 102 LSXR intake manifold. Not perfect heads but budget friendly since I have them.
SF1020, 4 inch bore, @28"
Agiain Wade, you made great choice brother.
If it doesn't I will get you to rebuild my engine to your specs.
