Spinmonster cam specs 2009
It's good that now they have hydraulic lifters that are guaranteed to 7500rpm.
So if I ever upgrade the runners to the high rpm I know the engine can spin safely to they rpm as my other hardware matches.
A lot of folks value better manners vs getting that last few HP. Me included. Do a search for "mild cam" here. Those guys aren't the ones getting all the attention though. Hell, I enjoy reading about big cams and big HP. I've done that before. Have no "want" to do it again. My recent build included a cam with "0" overlap that did quite well in the power department. Drives like a dream too.
It's the only way to get these to hang on in the top end.I notice a lot of people when they cam their LS3 there power drops off earlier than the OEM camshaft and therefore they have a lower red line even though they have more power.
Having 4 degrees of overlap in an LS3 is barely anything. Anything above 9 degrees is where your driving manners will start to become affected. This is with a good tuner.
If you looked at the dyno sheet, of the 230/234 camshaft, peak power peaks at 6100 and falls off 200rpm later.
Torque takes a dive after 5500rpm.
Seeing as though you are an old motorhead, I think you made a good choice with a 0 overlap cam.
Nice and smooth.
I have a 24 degree overlap camshaft in a stroker engine.
But having a cam fall off the top end faster than a stock cam is not good.
If the stock camshaft revs to 6500 you need one that holds at least the same.
Narrow splits are good for low- mid range power yes.
However without a longer exhaust duration, these engines do not hold up as well up top because you cannot get the EVO and IVC where it needs to be unless you introduce a lot more overlap by increasing intake duration higher to have a narrower split.
The exhaust side flows 65% of the intake so naturally you need 1-1.5 degrees of extra exhaust duration to help the exhaust side and improve efficiency and therefore power.
So you are saying cam motion and Brian Tooley have been doing it wrong?
Brian Tooley's 229/244 113 LSA camshaft makes excellent low end torque in the LS3 while making superior top end power.
Knocking 10 degrees off the exhaust will give you 5 degrees less overlap but also make less power and not pull as high.
This has been tested that larger splits make more power from 3500rpm+ compared to camshafts with less exhaust duration.
If you don't agree, you either have not tested this out for yourself like Brian has or you think he is wrong.
Most LS3 camshaft that perform well all over have 12-15 degree splits.
47 IVC. 57 EVO. Way low overlap. You do not need to add duration to get earlier EVO. You can use a wider LSA with more advance. Go to 118+6 and EVO is 59.
Not denying exhaust duration is good for top end power. But adding duration is not the only way to get earlier EVO.
But if you do not bump compression, earlier EVO hurts more than it helps.
This bullshit you assume I am saying is something you need to study and realise that maybe it is you instead who is ignorant.
It's common knowledge that 4-6 degrees of overlap in an LS3 and you still get stock like manners with a good tune. Any more than 9 degrees then your driveability begins to suffer.
If you think otherwise, then please disprove what I have stated.
Having less overlap also won't help either.
And yes an early EVO requires more compression to work properly.
It has just been proven that specifically with the LS3 head an earlier EVO makes more power and carries better. (of course up to a certain point.)
Brian Tooley knows his stuff as stated before.
You should test out his camshafts against your own and see how they compare.
Remember the exhaust stroke has this thing forcing all the air out of the cylinder. Unless boosted the intake has no assist.
Like if my wife took a two week trip to visit family and came home to not realize that the Mamo 220 heads and a 218/226 stealth cam were in the car...
