Spinmonster cam specs 2009
Old Jul 25, 2022 | 06:02 AM
  #161
General Lee 01's Avatar
Pulls pretty hard:
Old Nov 14, 2023 | 08:41 PM
  #162
PwrdbyLS1's Avatar
Originally Posted by KCS
Comp probably has the largest variety of lobes to suite pretty much any application. That Xtreme Marine series is a great lobe. I think it predates the LS engines though as I believe it was geared towards big blocks with heavy valves in marine applications where they sit at WOT and 5000RPM for long periods of time. I am using a high lift version of the Xtreme Marine that Comp calls the HUC lobes. Very little valvetrain noise, even with 1.8 rockers and .670" of lift.
I know this thread is old but it's hard to find people running 1.8 rockers with huc lobes. You run how much spring pressure to keep your valvetrain stable? I guess you use bigger pushrod too? I'm looking to use 1.8 rockers with my HUC lobes cam with johnson lifters, 11/32 pushrods in LS3 heads. My current springs have 140lbs at seat and 420lbs at .600. I was wondering if 480lbs open is necessary with 1.8 rockers.
Thanks!!
Old Nov 16, 2023 | 04:31 PM
  #163
Spinmonster's Avatar
Your experience with idle tuning differs from mine. I tend to find I have to lean the idle out for stability. When I fight unstable (surging) idle, it is typically rich. Or at stoich, which on a big cam is actually rich.
I do agree that higher spark timing at idle is nicer, but sometimes I need to be very aggressive on adaptive spark, which requires lower idle timing. I have found 18 degrees works quite well under most conditions.
Hi, thanks for the response.
I think it depends on the fuel you run. In northern states (colder climate) fuel is 10% ethanol and a car's commanded stoic is 14.7 when E10 really is optimum at 14.1
Old Nov 17, 2023 | 04:48 AM
  #164
Jimbo1367's Avatar
Wow. That’s such a nice thing to do for someone. Hats off to you. I’m sure the people really appreciated it!!!
Originally Posted by Spinmonster
I don't think there is a ton of arrogance. Many guys worked from the presumption that I was the arrogant azz and it was disproved with my driving 300 miles to a stranger's house in Maryland and fly-cut a guy's pistons and reassembled his engine for free. That single act of kindness showed many my true colors. I followed that up with flights to Texas, Kentucky, Connecticut, Pennsylvania, and Tennessee all for free and made some good friends (they paid travel costs). I really wasn't in it for the money. I shared cam specs for a very livable cam and got flamed for years. I posted here to stop outright misinformation. I posted to let there be empirical data for those searching for 'SpinMonster Cam'.
In my experience, guys see the data and accept the truth. Before there was rumor. In the end it's a daily driver cam and not max effort. Just don't say it dies at 6000rpms when it doesnt.
Old Nov 26, 2023 | 11:13 AM
  #165
grinder11's Avatar
Spinmonster is a big asset to the forum, and so are some of the rest......
Old Nov 26, 2023 | 11:23 AM
  #166
Agreed!! We have lots of talent here, Spinmonster, Che70velle, DarthV8r, among many others whose names I can't recall (or spell?) right now.
All are hugely appreciated!
Old Nov 26, 2023 | 11:59 AM
  #167
Thanks guys.
I hope everyone had a great Thanksgiving.
Old Nov 27, 2023 | 06:48 PM
  #168
grinder11's Avatar
Originally Posted by G Atsma
Agreed!! We have lots of talent here, Spinmonster, Che70velle(sp?), DarthV8r, among many others whose names I can't recall (or spell?) right now.
Another one who I really liked shooting cam specs back and forth with was Predator-Z. Never see him on here anymore.....
Old Nov 27, 2023 | 07:16 PM
  #169
Ryans99ls1's Avatar
I still have a pred z 230/230 cam sitting in my garage from my original ls1. Had a lot of fun running that cam way back when!
Old Dec 6, 2023 | 11:22 PM
  #170
He had a white Z28 if I recall. Good tech contributor.
Old Dec 7, 2023 | 11:19 AM
  #171
grinder11's Avatar
Yes, I think so. IIRC, he was in the United Arab Emirates, assuming in the armed forces. Sure hope he's still above ground......
