5.3 arp rod bolts
Old Jun 27, 2019 | 05:36 AM
fastlt1's Avatar
Default 5.3 arp rod bolts
At what hp or rpm is it recommended to install arp rod bolts in a gen 4 5.3 rod
Old Jul 14, 2019 | 06:45 AM
fastlt1's Avatar
Anyone
Old Jul 14, 2019 | 06:58 AM
cmysix's Avatar
it's just easier to use them then torque to yield bolts just tighten them to ARP specs, bottom ends on these LS motors is pretty tough, but TTY is a pain without a really good tool
Old Jul 15, 2019 | 10:17 AM
ColeGTO's Avatar
In my opinion, you''l find more broken/bent stock rod beams than stock rod bolt failures.
In addition, changing to an ARP bolt at a MINIMUM requires you to check the big end for roundness and size. You might be lucky enough to have a few tenths to work with to hone it back to round. After all that work, might as well just get a set of "cheap" rods and start from scratch.
Old Jul 15, 2019 | 10:40 AM
JoeNova's Avatar
Restricted User
Originally Posted by fastlt1
at what hp or rpm is it recommended to install arp rod bolts in a gen 4 5.3 rod
8400.
