Aluminum block bearing clearances
Hi
Let me start off with that I know aluminum blocks grow so we set the clearances up on the tight side of things...
However I'll be using my aluminum 5.3 block in a jet boat, and the coolant temp never gets above 140-160 degrees...
Knowing this should I still set this thing up on the tight end of things or should I set it up a little looser?
Will the block still grow as much with the constant cold water running through it?
Thanks
Thanks
I’ve seen .014” on main bearings with an aluminum LS7 rebuild, so different peoples idea of tight clearances can vary. Personally I’d try and get the water temp in the engine up toward 180-200 and set it up typical .002-.0024” clearance. Water temp will affect piston to wall clearances, lifter to lifter bore clearances, as well as valve to guide clearances among other things like oil temps which need to be upwards of 180-200. You can adjust water temps with a valving setup I assume?
On the hottest of days I think I've seen 180. But only at idle and once moving dropped down to 140.
I was planning to shoot for .0018 -.002 on the main clearances... My last engine (that lasted) was .0025 and seemed okay. But that was with an iron block.
