Free!
Old Jul 31, 2019 | 04:15 PM
Smokey B's Avatar
Got Flyin's have several others like BES Stroked Nova 828 hp 418 with 12.5 comp but that was a 8800 peak.
Old Jul 31, 2019 | 04:25 PM
spanks13's Avatar
I should have said, expect to make 800hp with a 23x intake lobe
Old Jul 31, 2019 | 04:56 PM
Smokey B's Avatar
I'm @ 268 in my head, have a 270 reference from MJ with 47 degrees of overlap. 1 given known is max lift of springs @ .840
Old Jul 31, 2019 | 05:35 PM
Smokey B's Avatar
https://ls1tech.com/forums/parts-cla...s-lifters.html
Like the
Straub cam @ 268... Ls7 heads need more exhaust duration. Would place the LSA @ 115
https://www.yellowbullet.com/forum/s...d.php?t=536277
Old Jul 31, 2019 | 05:58 PM
Millenium Z06's Avatar
I don't think anybody reasonable with any type of intelligence about the subject believe that. No way anyone's making 800 plus N/A with a 23X intake lobe
Old Jul 31, 2019 | 06:39 PM
Smokey B's Avatar
Spec'ed and had the heads made.... may as well do my own cam as well.
268/284 115 LSA 46° of overlap.
Best I can come up with 13.2 with 62 cc heads.
How does the valve events look is my main ?
Got plenty fuel and fire ready is the plan.
Old Aug 1, 2019 | 07:58 AM
Smokey B's Avatar
Checked email and Bobby asked peak RPM 7800 max. Thought I listed it but O's well. Gave a few reference builds and cam idea.
265/279 111 LSA 830 lift Low Lash solid roller. 50° degrees of overlap with a single plane intake. Changed just that quick from 268 @ .050. for a 7800 peak Let's see what Bobby recommends.
Be back in Houston n less than 5 hrs. Stop by and talk to me brother Zach and see what's up on introducing fuel underneath the 4500 TB (e85 plate kit to cool in coming air) on the Ls3 Super Vic topend setup. Injectors are to low to cool incoming air...Carb thoughts....and paying the Man.
+(Add) $ for ideas. O's well.
Gonna get this cam before the end of August. 100 a wk if need be.
Old Aug 1, 2019 | 09:26 PM
Smokey B's Avatar
Loving life wish I were Rich.......Hemi,Ford, Ls alll..........the group. I fund self. 2 lsx blocks that R Stuck, Owe $.Sellin? Yes....spoken on the largest bore before... 1 has roller cam bearings filled blk other 1 machined ready.......Stick too the script
Hemi's gen3 on the stand, Coyote Specifically
Got sleeves? Damn!
I am looking over this combo and I think 800 hp is going to be hard to obtain. But I can tell you what this thing is really going to need to make it happen. You are going to want to put a good intake on it like the CID. Also a 4.125 bore would make a big difference because of that very large intake valve. But if you must stay with the 408 her is the cam profile I would make you.Low Lash solid roller.263/279 Duration @ .050’’113 lobe separation 109 intake centerline.810’’/.810’’ lift with 1.8 rocker
1 order like uncle Jim, add (+) springs no Leans on parts.......luv when we R a dealer or distributor.
btw they said 840 lift springs add 1.85 ratio, instead of 1.8?
 Michael S. Palmer
Old Aug 1, 2019 | 09:44 PM
Smokey B's Avatar
For 1 given stroke ...give it your best Shot!
Repeat cycle for a given combination. Simple!
Y ask when a ph call is Free!
Cam Motion FTW!
Oh yea, we need spec's 4 both heads and the short blk combinations with ideas, Zach 4 lsxmag and 1 guy's junk and dealings.
Old Aug 3, 2019 | 03:53 AM
Smokey B's Avatar
Introducing fuel under the TB with a wet plate kit similar to meth injection result were similar to the meth test in the dyno section(from Zach/Oscar when @ Sam). Minimal hp gains +20 or so in best case(i think dumping fuel was involved), but the ability to control the fuel and air ratio entering the runner, besides the injector was a issue . Think using a small pill like a 25 to 50 jet as it wouldn't be dumping fuel rather a mist. = COLD incoming air with the fuel from the injector. Also a continuous, steady system of mist, which would make the intake cold to the touch top 2 bottom. And and easier to tune i would think...mist not dump. Higher compression is a better idea and use of e85.
Kicker...Oscar, Zach's better half & Cnc programmer (wink, wink we do cylinder sleeves) has a used Lsx block with roller cam bearings 4.125 bore , $1k needs a sleeve & small crack.....idk. Big O said he'd sleeve it for a $100 i purchase sleeve. Yet filling the block isn't a option. If the block can be welded i'm game if not too costly? idk. Next major ? I could do that big bore 4.200...idk but would.
Cam and springs for the 7's will be further discussed next wk....Zach has a family reunion this wkend. Oscar added it to my setting up the long block with the ls3 top..Playing on the dyno simulator the cam Bobby recommended on e85 did great...icl liked 111 rather than 109 small stuff.... 7800 strong thru out the rpm curve. Next wk...
Old Aug 3, 2019 | 03:59 AM
Smokey B's Avatar
Student from Sam was at the shop....seen what i have going on. Said your doing the most and you want that Lsx block...said 100 bucks a wk for 10 wks or 2 months & 2 wks ain't bad ...lol!
Old Aug 3, 2019 | 10:56 AM
  #32
Don't sprain your shoulder patting yourself on the back...… LOL
Old Aug 3, 2019 | 12:59 PM
  #33
Smokey B's Avatar
I took u off...just meeting great people who've done and can do anything i can or could dream of. Just the way it should be. I'm a very determined person who will....think about it. Kinda pround of who all i've dealt with and what's truely possible. i'm the super avg guy, that's mechanically inclined very much so. Most would have sold out by now, by each part with a goal in mind. I got the time nor will i go broke doing so.
Lsx block?? idk?? Research and call Zach or big O. Filling the block is not a option. Roller cam bearing installation is worth the selling price @ $1k..idk..
Springs and that cam are done Rowdy has to have it. One bill, long block & dyno included. Just paying for assembly with the 1st combo. Paid 4 the short blk work already.
Old Aug 3, 2019 | 01:20 PM
  #34
Smokey B's Avatar
I buy...get the best 2 build this POS...see what filling hole gets us. Under 730ish? I'll destroy it. Waste of time & $. Added with your not smart, Pride Hurt. F it.
at 13+ and 260 degrees. Lord Bless! Look @ those factory Ls3 heads...Rowdy
Old Aug 3, 2019 | 06:37 PM
  #35
Ever get the impression he talks to himself a lot? Even to the point of arguing??
Old Aug 3, 2019 | 08:03 PM
  #36
hiltsy855's Avatar
I need an interpreter LOL!
Old Aug 4, 2019 | 03:13 PM
  #37
Smokey B's Avatar
Different enough to hard fill a lsx cracked block and sleeve it. Bore it 4.200.
1 man's junk is another man's treasure.
