Need quick help on LS7 430ci cam selection
new LS7 block , 4.135 bore, 430ci
Callies Magnum crank
Oliver Billet rods
Mahle 930221635 flat top pistons, 2.5cc valve reliefs
Total Seal custom stainless top and Napier 2nd rings
Clevite H bearings
OEM LS7 heads done at Mast with ProFlow intake valves with lightly ported to match the valves, new valve guides and stainless valves, 65cc
head gasket .070 (yeah, I double-checked, not sure why this is here)
Align honed
Honed with plate
deck cylinders
set all bearing clearances for performance
balance and blueprint complete assembly
new cam
new ls7 lifters
new ctsv oil pump
LSXR intake
1 3/4" long tube headers
He seems to have narrowed down the cam selection to the following options, which are the shop recommendations for what they've used for many miles on LS7's without lifter failures. Main goal is reliability, no detonation issues, but he wants to do One Lap of America next year, so 5000 street miles pulling a small trailer (tires and tools) needs to be able to highway cruise pulling a trailer. Can't wait for a custom because it's tying up a lift at the shop. He's only going to rev it to 6500.
227/235 .614/.622 115+4 (he was going to pick this when he thought the motor was going to be 9.3 compression)
231/239 .617/.624 118+4
231/239 .617/.624 115+4
Any guidance for him on the cam selection to get him off the lift relatively quickly?
My recommendation will give you great driving manners once tuned and it will pull well everywhere even from low down in the rpm range.
236/248 115 LSA +3
With 12 degrees of overlap, this will have a nice muscle car idle, drive almost like stock and will pull ok up top too and will also be a pleasure to drive on long distances.
This would be the smallest camshaft I would use for what you are wanting to do.
Don't forget Lil John turbo specialist. ..... ....on the shelf maybe...but more than likely though
With the engine exactly as configured below, stated goals, and especially no intention to rev past 6500, I'm coming up with 234/242-117+4. it does not have the traditional split, but he won't need it due to RPM goals. Would favor a bit more grunt in the midrange.
One concern i have is the head gasket. That much quench, I'm concerned will lead to inability to run better timing due to being a bit more sensitive to detonation. If you get to convince him to drop that HG to .044 range and get quench under control, that would bring him up to 12.5 compression, and obviously that's pushing it. Problem is, I would not want to push dynamic compression more than about 8.4 with that head gasket, which will cost a bit in terms of throttle response. So that 231/239-115+4 cam would likely be a KR-ing SOB. Same with that 227 spec.
The 231/239-118+4 spec isn't bad actually. It would drive very tame, have very good intake vacuum, but I think would be just a bit lacking on midrange torque, where the 234/242-117+4 I think will feel a bit stronger and should still be pretty tame to drive. As to the rest of the valve train, I would run PSI 1511 springs and run the lift to around 0.625 on the intake, which would be nice and light and help restore that throttle response and snappiness, making up for the dynamic compression being a bit low. As to pushrods, run 3/8", and I'm assuming stock rockers as well. Make sure to install lash caps ont he valves to avoid mushrooming the titanium intake valves. I recommend caps on all 16 to keep the geometry equal on both intake and exhaust on a LS7 set up.
Hope that all helps your friend.
The heads don't have the Ti valves, and his math says DCR 8.8, SCR 10.8 with that cam, I don't have all the numbers to verify.
So his .050 VEs for the 227/235 115+4:
IVO 2.5
IVC 44.5
EVO 56.5
EVC -1.5
Jacob's suggestion, 234/242-117+4:
IVO 4
IVC 50
EVO 62
EVC 0
Overlap: 4*
Overlap Bias favors exhaust
Bortous suggestion #1, 236/248 115 LSA +3:
IVO 6
IVC 50
EVO 62
EVC 6
overlap 12*
No Overlap bias
Bortous suggestion #2, 234/246 116 LSA +3.
IVO 4
IVC 50
EVO 62
EVC 4
overlap 8*
No overlap bias
Wow, the recommendations have uncannily similar VEs
IVO 2.5
IVC 44.5
EVO 56.5
EVC -1.5
IVO 4
IVC 50
EVO 62
EVC 0
Overlap: 4*
IVO 6
IVC 50
EVO 62
EVC 6
overlap 12*
No Overlap bias
IVO 4
IVC 50
EVO 62
EVC 4
overlap 8*
No overlap bias
How do I correct that formula?
I had an LS7 with a 243/256 .650" lift cam and headers/stock intake manifold and it drove perfectly plus it was setup as a road race car (2800lb RX-7 chassis). Made only 520rwhp.... but did go low 10's@ 110mph 1/8th and 138mph in the 1/4 on 91 octane thru dual 3" Random Technology catalytic convertors...
I have 3 cams 2 of which Geoff has speced for me and one is a thunder racing tr224 from like 08, That cam has been through basically 3 different motors for daily/street all I can say is I’m very happy with all around service and performance but that’s is just my opinionnot-a-sponsor.com
