Projekt Lazarus - Numbers Posted!!
Old Mar 23, 2020 | 03:52 PM
  #841
that kids first word will be "turbo" just to **** him off
lolololololololololzzzzz!
Old Mar 23, 2020 | 07:42 PM
  #842
Darth_V8r's Avatar
Moderator
As long as his first word is not coyote
Old Mar 23, 2020 | 08:22 PM
  #843
ddnspider's Avatar
Amen!
Old Mar 23, 2020 | 08:52 PM
  #844
01CamaroSSTx's Avatar
Congrats!
Old Mar 23, 2020 | 11:18 PM
  #845
98_WS6_M6's Avatar
Lol!!!! Maybe Cryote
Old Mar 24, 2020 | 04:38 AM
  #846
Jimbo1367's Avatar
Awwwww. Congrats on the 1st grandchild. We expect this baby to be in some engine pics once he/she can hold a wrench LOL
Old Mar 24, 2020 | 08:31 AM
  #847
Darth_V8r's Avatar
Moderator
That is the best catnip, troll plate ever
Old Mar 24, 2020 | 08:56 AM
  #848
Thank you Lord for sending down another gear head!
My grandson is three and loves working in the shop with his paw paw. He's become well educated on tools and can point out certain parts of an engine.
Old Mar 24, 2020 | 09:05 AM
  #849
bortous's Avatar
Wow. I need to get a move on and make a child.
But first find the woman.
Old Mar 24, 2020 | 11:47 AM
  #850
Darth_V8r's Avatar
Moderator
That is seriously awesome! I thought about asking my daughter to put a wrench in his hand for a pic...
Old Mar 24, 2020 | 01:03 PM
  #851
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
What a Beautiful Baby!
Congratulations Darth
Old Mar 25, 2020 | 10:51 AM
  #852
bortous's Avatar
Hey Darth did you end up going for the Manley Spring kit instead of the PAC 1209x you originally said?
Looks like we are both running Yella Terras 10mm and same ratio.
Old Mar 25, 2020 | 11:21 AM
  #853
Darth_V8r's Avatar
Moderator
Yes I did. But not due to the rockers. I have .747 lift and am planning for 8k
Old Mar 25, 2020 | 11:32 AM
  #854
bortous's Avatar
The rockers should be all good as long as spring pressures are set up correctly.
What spring pressures you running to suit that RPM?
Mine are 200lb seat and 500-510lb open.
Old Mar 25, 2020 | 11:34 AM
  #855
Darth_V8r's Avatar
Moderator
165 seat and 515 open. i bet my valves are lighter though. again it isnt only about the rockers.
Old Mar 25, 2020 | 11:38 AM
  #856
bortous's Avatar
That's lower spring pressure than what I was expecting.
I think you got the titanium valve option too didn't you?
The cam motion LLSR is probably less aggressive than the comp grind I'm running.
Would a big 2.230 valve weigh less than a 2.165 Hollow stem valve?
Old Mar 25, 2020 | 11:39 AM
  #857
spanks13's Avatar
Curious how you like the 1209x. I sprung (lewl) for the 1238x for mine. I expect them to have a much shorter life than the 120xx series.
And I can say 100% yes the Ti intakes are lighter than the smaller hollow stainless. My factory Ti intakes are 77g.
I don’t think you should run hollow stem valves with solid rollers, but this LLSR stuff might be an exception to that.
Old Mar 25, 2020 | 11:40 AM
  #858
Mickyinks's Avatar
pac 1209
Old Mar 25, 2020 | 11:46 AM
  #859
Darth_V8r's Avatar
Moderator
Yes and Yes
Old Mar 25, 2020 | 11:53 AM
  #860
bortous's Avatar
I don't think Tony would let us run those hollow stem valves if they were not suitable.
I would say it's accurate how hollow stem valves are ok with Low lash solids.
However I would call the comp solid more of a medium lash.
I have spoken to a few people in the past who would never use a hollow stem valve with a solid roller.
Maybe back then things were different but technology progresses.
That 1238X spring is quite a heavy spring and long life is certainly not going to happen.
The Manley has a lower spring rate so a reasonable service life can be expected.
From memory the 2.165 valve weighs 87g I think.
