Projekt Lazarus - Numbers Posted!!
Old Jul 26, 2020 | 06:52 AM
  #1081
bortous's Avatar
Launch, that is a nice setup! I agree with you on the stroke. Keep it 3.622. I personally have always preferred to keep a motor over square. If you put a 4 in stroke in there you will make the same power but with 30-40 more torque. If you do stroke, sleeve it and punch it out to 4150 or so. My opinion. Honestly, I wish Chevy had not stuck with 4.4 bore spacing and had decided to go 4.5. Woulda made the block a half inch longer and wider. But think of the options and what that would have done for the platform.
Your heads sound like C5R heads. They were a really small ls7 style port but still flowed amaze *****. If the top ten fastest NA lost in the racing section is still valid, check out how many are C5R heads. Maybe that will be worth some motorvation?
It is just not in the cards to swap out the rockers. I am too close to getting it running. Plus the springs were chosen with the YT mass included in the equation. So, it is not as simple as swapping out rockers.
@Bortuous, Chevelle posted 11 grams heavier over the top vs stock. It might have been in this thread in the past few days. Not 100% sure. I would be curious to know the over-the-nose weights of some of the other rockers mentioned also. The info might be in the gen3 stickies. I will have to check.
I know Chevelle posted it but I am wanting to know if the Cathedral yella terra rocker is the same weight as the LS7 type.
Can't find the info anywhere.
Old Jul 26, 2020 | 08:53 AM
  #1082
ramairws6's Avatar
Originally Posted by bortous
It might be a reason.
However the majority of the time, issues arise because the valvetrain was not set up correctly. Incorrect matching of components etc...
The way Tony has set everything up etc, I would leave it as is. The combo will work very well. It's proven.
Your yella terras will be fine just as they were on Josh B's engine.
His setup was more aggressive than yours with a PAC 1209X spring and was revving out to 7800rpm or so.
He was running the same solid camshaft as me but a 264/276 112 LSA.
Tony has gone over this so many times and clarified everything to the best of his ability.
I guess you didnt understand my post. This was Tony's complete package and sent to this builder. Hell, they even went back and forth over the phone about all the issues to try to fix it all out. I will just state that the customer was not happy. As far as the studs? I would assume they were the size that Tony puts on all his 260 Trickflows but i am just assuming.
Old Jul 26, 2020 | 08:56 AM
  #1083
ramairws6's Avatar
This is a great question to ask as i do believe the Yella Terra seem to not have issue on the Cathedral head?
Old Jul 26, 2020 | 10:51 AM
  #1084
Darth_V8r's Avatar
Moderator
I would have thought his setup was less aggressive than mine, because I have shorter duration and taller lifts. And I am planning a 8000-8200 shift point. Tony and I had to go to nextek springs because we were not sure the pac1209x would be enough. That was the original plan anyway.
Either way....
Old Jul 26, 2020 | 10:56 AM
  #1085
Darth_V8r's Avatar
Moderator
On the bolts, the 10mm upgrade is not standard. The heads come from the foundry set up for 8mm. Even when I did my 346 I stepped up to 10mmhardware. I personally think it is one of the best upgrades you can do. Especially as spring rates get pushed.
I paid extra for the 10mm kit and for Tony to drill and tap the grass for 10mm. Not everyone does this.
Old Jul 26, 2020 | 11:45 AM
  #1086
bortous's Avatar
Either way....
Oh ok.
Last I checked the 1209x has a 500lb spring rate vs 435lb for the next tek.
Old Jul 26, 2020 | 11:46 AM
  #1087
bortous's Avatar
The 10mm option should be a requirement.
Old Jul 26, 2020 | 12:36 PM
  #1088
spanks13's Avatar
Did I miss a part where the YT have already caused a problem before the engine even fired up? Lol.
Old Jul 26, 2020 | 12:40 PM
  #1089
Darth_V8r's Avatar
Moderator
Nextek is higher seat pressure and lower open pressure vs the 1209x. You are correct the pac has a higher spring rate.
Again, what drove the parts selection was lift. Many are afraid to push lift much past about 625-650. Normally it is not warranted.
In this case, we specifically wanted to make sure the heads did not stall so we could run higher lift to get increased duration at moderate lifts. It is quite aggressive. Just does not need 600 lbs open pressure to control with the very light valves.
Old Jul 26, 2020 | 01:22 PM
  #1090
bortous's Avatar
Makes sense Darth.
How much seat pressure are you running?
Old Jul 26, 2020 | 01:28 PM
  #1091
Darth_V8r's Avatar
Moderator
makes sense darth.
170-175
Old Jul 26, 2020 | 01:42 PM
  #1092
bortous's Avatar
170-175
Thats right.
Lower than mine because of titanium valves.
You have 94g in less weight on the intake side.
Not sure if it's been said already, but what is your rwhp goal?
I'm hoping for around 700 on this setup.
Titanium valves will add about 12 rwhp after seeing one of Mamos customers do this.
I have a feeling the low lash solid may not make quite as much power as the comp cams version.
I remember asking Tony about it and he was very confident to go the comp cams route because they have worked very well for him. Who am I to not listen? So I went ahead.
I like the customisation cam motion offers though.
You can choose the duration and lift in increments.
Old Jul 26, 2020 | 02:40 PM
  #1093
Darth_V8r's Avatar
Moderator
No real HP goal. More of a 9s NA goal. But not your typical track car.
Track is an hour away. I want to be able to drive an hour to the track, rip a 9.xxx pass, and the drive an hour home.
My previous build with the LPE top end ran 10.1@134. I think it had more in it, but I also figured I could pick up 50-70 hp via top end magic and make a 9.xxx a bit easier to do with poor driving skillz
Old Jul 26, 2020 | 09:30 PM
  #1094
Floorman279's Avatar
whats the best way to weigh the rocker on the nose? i got both crower and YT to weigh
Old Jul 26, 2020 | 09:54 PM
  #1095
spanks13's Avatar
Thats right.
You're hoping for 700whp from your engine?
Old Jul 26, 2020 | 10:05 PM
  #1096
AINT SKEERED's Avatar
I thought he said crank in his early post on his own thread but now it seems he meant rwhp
Old Jul 26, 2020 | 10:16 PM
  #1097
bortous's Avatar
I'm referring to Darth's setup, not mine.
Mine will be around 700hp at the crank as previously discussed.
Old Jul 26, 2020 | 10:17 PM
  #1098
bortous's Avatar
No sir you have it wrong.
I'm referring to Darth's setup.
Old Jul 27, 2020 | 06:40 AM
  #1099
Darth_V8r's Avatar
Moderator
I hope your kidding....It wouldn't be a wise decision to drive the race car to the race track....
No I am actually serious. I think that would be badass. Think about drag week where they drive track to track hundreds of miles. I want the car to be fast but I also want it to be durable and dependable- at least as far as hot rods go.
Old Jul 27, 2020 | 02:45 PM
  #1100
spanks13's Avatar
That's when you push it down the road and call AAA lol
