Compstar CCW Crank
Old Sep 21, 2019 | 06:30 PM
JakeFusion's Avatar
Super Hulk Smash
Default Compstar CCW Crank
I'm looking at the Dart CCW crank and Compstar's CCW crank.
The Dart seems to be doing very well, but it's priced quite a bit more than the Compstar.
I'm wondering if anyone has any real-world data or usage with the Compstar Crank. Is it vibration free? I thought I heard it was clocked differently than the Dart crank and had some issues there, but I can't remember where I heard that.
Looking to use it with a Dart SHP Block in a 427 with a 4" throw for a 7500 RPM or so operating range.
Old Sep 22, 2019 | 07:50 AM
joyridin''s Avatar
I should have my new Callies CCW crank tomorrow, but it will not be in the engine until Spring. An Engineer at Callies said they are a biatch to balance, but they are cherry when they are done.
Old Sep 22, 2019 | 08:10 PM
DualQuadDave's Avatar
https://www.yellowbullet.com/forum/s...=2585437&amp=1
This thread had some good info in it. I am going either cut down stock LS7 crank or the Compstar CCW in my next motor.
Old Sep 22, 2019 | 08:12 PM
Smokey B's Avatar
Good looking out... was gonna post the same thread.
Old Sep 22, 2019 | 10:14 PM
gnx7's Avatar
How much HP are you trying to make? n/a?
A Molnar crank is good for 1500hp+ ..... I made 1200rwhp on a stock LS cast crank turbo motor for 3 years spinning it to 7500+rpm with cheap Compstar rods.
I built a 441 (4.190" bore) with an LS7 crank/rods to spin to 7500-8000rpm as a road race motor n/a... have yet to run it....but don't expect issues aside from basic rebuilds.
Old Sep 23, 2019 | 08:51 AM
62nalide's Avatar
I have both, my Dart is in a 427 for boost and building a bad up one with the Callies CCW crank. Both will see 77-8200rpms, should get the Callies here this week.
Old Sep 26, 2019 | 06:53 PM
JakeFusion's Avatar
Super Hulk Smash
750-800 or so NA. Want to be able to spin to 7800-8000 at the most but looking at 7500+ more in general. My cam isn't that large for a 4" stroke. So, I'll have to see how it does. Have a FAST Med Runner for now but may move to a TSP Billet or LOD intake eventually.
I have looked at Molnar a lot, but I like the idea of not having a flexing crank at high RPM to keep it together for a bit longer. I'm always winding it up down the backroads around here.
But that link is helpful!
Old Jun 23, 2020 | 03:06 PM
bmf5150's Avatar
How is the Callies compstar ccw holding up ?anyone have bad or good luck with them ?
Old Jun 23, 2020 | 06:22 PM
joyridin''s Avatar
I have about 800 miles on mine. It has been great so far. Running about 15 psi of boost on a 418 cid LS3. JE Ultra pistons and Callies rods all balanced at Callies. Smooth as silk to 7k.
Old Jun 23, 2020 | 10:02 PM
bmf5150's Avatar
Good to hear ,turbo or supercharger
Old Jun 24, 2020 | 06:35 AM
joyridin''s Avatar
Supercharger.
Old Jun 24, 2020 | 01:19 PM
bmf5150's Avatar
Ok cool i been going back and forth between the Callies compstar ccw and the dart ccw crank
Old Sep 30, 2020 | 07:34 PM
startingstock's Avatar
I was wondering if you knew the weight difference with the extra counterweights. I have my 438 all together with the compstar ccw, but never weighed it. I'm sure its negligible, but just curious
Old Oct 2, 2020 | 02:15 PM
Chuck Brigham's Avatar
Running this crank in the same block you mentioned above. I run it up to 7500 without issues on my turbo 427. Not sure on the power it made, but i pushed it to 27# and it seemed fine to me...
