C6 LS3 416 Build Started
Old Jan 13, 2020 | 02:31 PM
62nalide's Avatar
When do you expect to fire that thing? Congrats man.
Old Jan 13, 2020 | 03:01 PM
icanski2's Avatar
I'll start on the install in a couple weeks if I can get all my other crap I own to quit breaking!. My daughter's BMW diesel, and my F250 have been keeping my tools pretty busy lately. Along with my girlfriend's son with a 4x4 GMC 5.3 that has oil pressure problems too! Joy! I put a new sensor and replaced the DOD screen under it so I'm hoping its an oil pump pickup o-ring.
Old Jan 18, 2020 | 01:51 PM
po feng's Avatar
Compression ratio?
408ci use?
Old Jan 19, 2020 | 02:29 AM
icanski2's Avatar
Originally Posted by po feng
Compression ratio?
408ci use?
Static 11.2:1 Dynamic 8.45:1. As far as the "408ci use" part of your question, I don't understand what you are asking.
Old Jan 19, 2020 | 06:52 AM
po feng's Avatar
I mean: your engine is 408ci?
Because I'm preparing for 408ci.
But I don't know how much compression rate to use. Because I am in Taiwan, few people in Taiwan use the Ls engine, so there is very little information.
I want to use Frankenstein m311 heads.(Does M311 keep the original 72cc?)
How much compression should I use?
Compression rate i want to use medium,Because I don't want to be too high Compression , the weather in Taiwan is too hot, and I'm afraid the temperature will be too high.
Or can this kit be bought?https://www.cnc-motorsports.com/comp...E8XdNttxHEFiKo
I want the assembly to handle Turbo 1200hp/7300~7800rpm / 98 fuel.Will use E85 on weekends.
Would you like to share information?
sorry..my English is not good.
Thank you very much for your reply.
Old Jan 20, 2020 | 03:34 AM
icanski2's Avatar
Sorry for delayed reply. I've been crazy busy. Don't worry about your English. I'm from Texas and don't speak it very well myself!
  • My engine is a 416ci.(a bored and stroked LS3)
  • As far as your question about compression for your turbo build, I'm really not an authority on that subject. You may want to start your own thread and post the questions for the many experts here. This a very basic explanation from an idiot (me): Static Compression is a fixed value that is a result of the cylinder components used (pistons, head gaskets, heads.........) and volume of the cylinder. Dynamic compression ratio is the result of what the valve opening and closing events caused by cam selection does to your static ratio. VERY OVER-SIMPLIFIED DESCRIPTION. So your the goal of what you want to do with your car will dictate what those values need to be.
  • Yes the Frankenstein M311 heads keep the 72cc.
  • Sounds like you are going to have good fuel so you really need to talk to a builder and iron out all the variables that go into sourcing the correct components. (how fast you want to go, car weight, Transmission type, rear end gearing, drivability, budget........) I highly recommend talking to Kyle at Thompson Motorsports. He can probably come up with a comparable rotating assembly to the one in your link or build and ship you a bad *** engine. Thompson Motorsports
Old Feb 2, 2020 | 02:51 PM
Jimbo1367's Avatar
Any updates on this LS3 stoker yet? Has anyone seen any dyno data with these Frankenstein heads?
Old Feb 6, 2020 | 11:18 PM
icanski2's Avatar
Nothing to report yet. I'm not done with the install. Too many other projects going on.
Old Feb 7, 2020 | 12:27 PM
KW Baraka's Avatar
C'mon man, focus.....FOCUS!!!
KW
Old Jun 23, 2021 | 01:43 PM
Wdmathis91's Avatar
Starting a new build on my vette. I cut my oil filter open and it was full of pretty shiny things. The poor girl died from lifter failure. I ordered a new forged short block from Thompson Motorsports yesterday and will order the long block completion parts from them in the next couple days after I figure out the cam specs.
Blue printed New LS3 aluminum block
ACL coated racing bearings
K1 forged crankshaft
4.000" Manley H-Heavy 4340 forged connecting rods with ARP 2000 rod bolts
Diamond or Wiseco pistons with GFX file fit rings
ARP Main Studs
Frankenstein Thompson Edition M311 11* CNC 6 bolt heads
Extreme duty stainless intake and extreme duty solid exhaust valves
Billet Rocker Rails
.660 springs
3/8 pushrods
ARP Head Studs
Melling Select High pressure oil pump
Billet adjustable timing set
Johnson 2116LSR Lifters
Trunion Upgraded Rockers
GM MLS head gaskets
GM MLS head gaskets
Cam is still TBD
Any update on this yet?
Old Jun 24, 2021 | 12:54 PM
icanski2's Avatar
The project has been stalled for over a year. During that time, I did a huge remodel project on my house, and my daughter was seriously injured in a car wreck last summer that put her in the ICU for a while. As a dad I've never felt so helpless because we couldn't see her due to Covid Protocols. She had do lay there alone. We truly are blessed though. It was a tough recovery for her but luckily she is doing great now and went back to college at The University of Arkansas. That crap really took a lot of wind out of my sail. I had no interest in working on it and my mind wasn't in the right place to concentrate on the task if I did. I'm actually slowly getting started on it again. I just ordered some Hinson tranny mounts a few days ago and have started following the forums again. I have 95% of the parts I need and I am working on a project punch list to get organized. Its a pain in the *** because I kinda forgot where I left off on it. I labeled the bolt bags and was pretty organized but there are some "mystery bolts" laying around. Hell, I'm afraid if I get it running I will have to find a place to store all the **** I have piled up on it! LOL!
A new pic of how it sits right now.......This thing is a great storage device!
I should be ashamed of myself for neglecting this example of LS greatnesss!
Old Jun 24, 2021 | 01:16 PM
  #32
Hey, you had a MAJOR priority getting your daughter back in shape! I sincerely hope she is doing well.
Ease back into car work once you feel good about it, and you will!
See ya around!
Old Jul 3, 2021 | 11:00 AM
  #33
Jimbo1367's Avatar
I agree. Your daughter first. Once she’s back to normal, doing her thing, then everything else can go forward.
best wishes to your daughter
Old Jun 10, 2022 | 10:53 AM
  #34
ws6-formula's Avatar
I know this is an old thread but I am wondering what length pushrods you guys went with?
I just ordered the m311's and they are going on an lq9 421 stroker.
Thanks!
Old Jun 10, 2022 | 11:27 AM
  #35
84ta406's Avatar
Thanks!
There is really no correct answer unless you measure yourself. So many variables with aftermarket parts.
