L92 head swap on 408, opinions?
ya, its another one of these threads.... But this time we dont give two ***** about low end TQ.
So....Im considering swapping from small port cathedrals(PRC Terminator 200cc) to stock/milled l92's. 1/4 mile only car with a 5200rpm stall, low end TQ does not matter.
Is it worth the effort? If I am only going to gain 20hp or 2 mph maybe ill just spray it more?
I have always felt my 408 was a bit of a dog and I have a set of stock L92's on the bench. I would also be going with 102mm intake and larger headers.
Also, my Current camshaft has quite a bit of split, I wonder if I could reuse it as well? If PTV allows of course.
1/4 mile only car. runs 11.00 at 125 typically on motor, #3250, sub 1.5 60's. has been 10.70's @ 127 on a few extraordinary runs. Current setup doesn't seem to make much power over 6000rpm,
408 lq4
Callies rotator
Wiseco -8cc reliefs
Old PRC Terminator heads. Edelbrock casting, 2.02 valves, 200cc runners. Were supposed to flow 300+cfm? cant find any info on these odd ***** anymore.
11.5 cr
fast 90/90 unported
Cam Motion 253/266 .643 .629 113
1 3/4 headers. open exhaust
Th400 w/Transbrake
5200 stall
9"
28" Et Drags
408 lq4
Callies rotator
Wiseco -8cc reliefs
11.5 cr
fast 90/90 unported
Th400 w/Transbrake
5200 stall
9"
28" Et Drags
Moderator
Received 1,852 Likes
Your cam is screaming for ls3 heads. Use mid runners fast intake. If you have 93 octane that cam will let you run 12.3:1 compression which I would also recommend. Its a massive can for that 408
Agreed on camshaft.
That much of a stall Im go say you'll benefit ditching the fast intake and going to a single plane intake....
I’m in doubt of those 200cc Cathederal heads flowing 300 cfm. L92 heads would be good idea along with a 102 intake or single plane as mentioned. Leave the cam, yes to bigger headers with 3” exhaust system dumped and say goodbye to 11s
Thanks guys. I may give it a try, got nothing to lose. If I had a ton of cash to throw at this thing the decisions would be easy..... PRC 260, LOD intake, the works.
Send those Stock L92 to Frankenstein. After this past LS fest i would never buy a aftermarket LS3 head. I witnessed alot of aftermarket LS3 heads get they feelings hurt with some Frankenstein LS3 heads.
