07 5.3 dod noise
Old Oct 7, 2019 | 04:29 PM
hpadder's Avatar
Default 07 5.3 dod noise
Hi I bought a 07 gmc envoy with a 5.3 that someone started on and I picked up where they left off. It had new dod and the regular lifters replaced. The valley lifter tray was also replaced. I have never heard a top end make so much noise. Anyone have any thoughts it has great oil pressure and the noise is all top end? Dod ? Activating?
Old Oct 9, 2019 | 06:50 AM
Ls7colorado's Avatar
loose rockers?
Old Oct 9, 2019 | 05:46 PM
hpadder's Avatar
Thanks I checked the rockers and they where tight. What happens if the plug on the valley tray is unplugged? I know it’s not a new subject but I’m looking to see what other people might think or had go wrong. I have only ever done a complete delete and had good luck with those.
Old Oct 10, 2019 | 04:37 PM
00pooterSS's Avatar
New lifters are loud as hell until the pump up
Old Oct 10, 2019 | 05:45 PM
hpadder's Avatar
Well I will run it longer and see but it was running for over an hour and was at temp. And was holding 40 lbs pressure. Thanks I just want to get this figured out.
Old Oct 10, 2019 | 05:48 PM
00pooterSS's Avatar
Damn that is a while. When i do new lifters I hold it at 2000-2500 rpm for about 30 seconds and flare it a couple times helps them pump up quickly.
Old Oct 10, 2019 | 05:57 PM
Originally Posted by hpadder
What happens if the plug on the valley tray is unplugged? .
the check engine light will be on and it will shut off the DOD cylinders, unless its tuned
Old Oct 10, 2019 | 08:33 PM
hpadder's Avatar
Thanks for the info guys I have done other motors and had great luck. This is the first that I left it stock only because the person I bought it from spent the money on the stock parts. I feel stupid because I should have none better but I was going to turn the dod off with hp tuners ASAP and though I would be ok.
