GM 5.3 misfire
139K. Was driving down the highway at 60mph. Check engine light started flashing. Pulled over and it was ticking. Shut it off. Towed back home. Comp testing showed 160-180 for all of the cylinders. Can confirm that the valves move with the covers off. Codes are for misfire #4 and low oil pressure. Anyone have any ideas?
apologies if wrong forum...
Oil level is fine. Have not checked the filter yet. Yes it is an AFM motor. My very first thought was lifter.. but the valves all move fine and the compression testing shows excellent comp on all cyclinders.
Not sure, though one of the AFM/DOD lifters might have partially collapsed and cause a miss.
I really appreciate your ideas.
