LS2 Budget build
Old Nov 8, 2019 | 06:06 PM
cmysix's Avatar
Originally Posted by Chris25
TFS220 as cast a fast 102 intake port matched to the heads and 102 TB with a decent cam 23x/23x cam really not much to it.
aint that simple, look at my SIG below, that's what I'm running on a LS2 now your going to tell me the 102 gave you 50 HP? what CR are you running?
Old Nov 8, 2019 | 07:57 PM
Mavn's Avatar
"I MAID THEESE"
Somethings wrong with your car or the dyno ls stingy .
I've made 460 wheel 4 times on 4 different cars with stock casting 243 heads, a decent cam, and a fast intake . Oh and these are ls1 5.7l fbodys. Hell my stock ls3 vette with a tune laid down 380 lol
Old Nov 8, 2019 | 08:29 PM
Chris25's Avatar
Lol funny thing is mine makes more than my sig that was my old exhaust setup
Old Nov 8, 2019 | 08:33 PM
Chris25's Avatar
Stock bottom end .......
Old Nov 8, 2019 | 09:53 PM
Smokey B's Avatar
Again didn't read post or any of the...but your ?
500 then FI.....
Most will BS u...get a goal + a budget.
Stock Crank can take X amount of ...on a good tune with a Future in Boost.
Rods need to be on point. Requires Change!
Compression inline with the amount of FI pressure > with cam (with fuel grade in mind.)
Build 4 na hp X 2 ....... = 9.5 compression and asking the long blk 4, 500 hp before 14.5 psi is added which would = 1000 hp.
A Ls with 9.5 comp and 500 hp .....
Old Nov 8, 2019 | 09:56 PM
Smokey B's Avatar
Google 500 hp LS and work with the above statement...1000 made easy..
My fault...a damn non re sleeved blk...tune must be spot on. Sleeve Gone .... leaking!
Old Nov 9, 2019 | 07:43 AM
cmysix's Avatar
I would be more inclined to think your tuner is playing with the #'s or something else is wrong, My car was tuned By Mike C. at Vengeance Racing on a brand new 2000 HP dyno, Mike C. is one of the best LS tuners in the world, WITTNESSED by several world records held by Vengeance Racing ALL tuned by Mike C. NOTHINGS wrong with it, Last time on the dyno with this set-up 425 RWHP 418 RWTQ So at the crank somewhere around 475, What I relly want to know is what CR do you have? your LS3 is weak, this car bone stock with a tune laid down 379, your right something is wrong your LS3 with a tune should have been around 410 in a manual car
Old Nov 9, 2019 | 07:46 AM
cmysix's Avatar
And your answer Chris, Yes it is a stock bottom end. I am is the process of pulling the heads, going to have them milled, going to bring the CR up to 11.5-1. That why I'm interested in what CR these other dyno racers are running?
Old Nov 9, 2019 | 11:55 AM
Chris25's Avatar
No I meant mines a stock shortblock nothing has been touched.
Old Nov 9, 2019 | 04:46 PM
Mavn's Avatar
"I MAID THEESE"
No dyno racers here . Every fbody I've owned that made 450 + wheel has gone 10s. I have multiple threads if you search my name
Old Nov 9, 2019 | 04:49 PM
Mavn's Avatar
"I MAID THEESE"
My vette is #2 on Corvette forums for fastest bone stock ls3 vette at the track. So no, I'd say it's not weak. Lol it's a an auto. Not manual. Lol And no my tuner doesnt play with the dyno numbers. considering every LS1 I've built has gone 10's . Lol my 416 ci 6 speed car I built trapped 137 at full weight (3600lbs) and dynoed 610 wheel.
Not arguing. Just stating facts. And Mike is meh . But that's just my opinion . Likeni said earlier. You can search my name and find all the info you need to huild fast stuff . I post everything for people to learn .
Old Nov 9, 2019 | 05:54 PM
  #32
Jonathan8186's Avatar
Originally Posted by Jonathan8186
So I finished my 5.3 LS swap and have been driving it for a month or two and like everything want more HP, keep in mind this truck is a 05 Colorado crew cab with 6” lift and 33x12.50 tires. Trans is a built 4L60E with 2400 stall. The 5.3 has a TSP cam stage 2 #25-TSP212218R6112
My question is what do I need to do to the LS2 before I install it to hit the 500hp
I’m definitely going turbo in the future.
The LS2 is a 06 GTO motor and it should be delivered this week.
Thanks
Looking for Tuner in VA
Old Nov 9, 2019 | 06:35 PM
  #33
Chris25's Avatar
Your car should be making North or 470 easy.
Old Nov 20, 2019 | 06:25 AM
  #34
Default 243 heads
Originally Posted by G Atsma
Good info bortous! To add to that, TSP does CNC porting/valve jobs quite reasonably, plus they can grind/recommend a cam to suit your needs.
I should be getting the heads back today from Katech, got them ported. my question is I’m using LS9 head gaskets from Brian Tooley racing it’s a stock LS two short block with flat top pistons my question is how much can I take off for the heads?
Old Nov 20, 2019 | 10:40 AM
  #35
What is your goal?
Old Nov 20, 2019 | 11:07 AM
  #36
i’d like to keep it at the stock compression ratio 10 1/2 to one
Old Nov 20, 2019 | 02:24 PM
  #37
Mavn's Avatar
"I MAID THEESE"
You donYou need to mill them porting doesnt affect chamber size
Old Nov 20, 2019 | 03:19 PM
  #38
Yeah but I think the LS nine head gaskets are thicker than the LS two head gaskets correct?
Old Nov 20, 2019 | 03:26 PM
  #39
LS9 thickness- .055
Most other LS- .052
Old Nov 21, 2019 | 06:45 AM
  #40
cmysix's Avatar
However you can buy head gaskets in almost any thickness you want
