SacCityCorvette is having a Christmas sale!
Come check out SacCityCorvette’s Christmas Sale!
If you have a Corvette click this Link to see what we have for you!
www.saccitycorvette.com/HolidaySale.html
Billet Oil System Improvement Parts - LS engines with tight clearances and tiny needle bearings in the lifter rollers don't tolerate particles in the oil. They cause lifter failure that LS engines are prone too. These Billet parts will help keep unfiltered oil out of your bearings and lifters and improve oil flow and engine life. Click the link info and sale pricing!
http://www.saccitycorvette.com/Holid...provement.html
![](https://i1119.photobucket.com/albums/k623/saccitycorvette/Oil%20Improvemnt%204%20pcs3_zpswxuetx2l.jpg)
AlignIt Tools - These simple but very effective tools help make easy work of aligning your Timing and Rear Main Covers and getting the seal installed correctly. CNC Machined to exact tolerances, the AlignIt tools get the covers centered perfectly with the crank to prevent premature seal wear and leaks. The O-ring design makes for a perfect snug fit no matter the temperature that can cause expansion/contraction of engine covers, crank & tools that will hinder a perfect fit. The O-ring design eliminates this problem. Patent No.: US D864,691 S
www.saccitycorvette.com/HolidayAlignItTools.html
![](https://i1119.photobucket.com/albums/k623/saccitycorvette/RM%20TC%20Sim%20%20%206%202018_zpswbdvzmgj.jpg)
__________________
Don't forget to check out our products at www.saccitycorvette.com
![](https://ls1tech.com/forums/signaturepics/sigpic197936_1.gif)
If you like our products, tell others! If not, tell us!
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
We have more then just these parts, so don't miss our Christmas/New Years sale! ![](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
https://www.saccitycorvette.com/HolidaySale.html
__________________
Thank you Toofast! Merry Christmas!
__________________
Merry Christmas everyone from SacCityCorvette!
__________________
Only a couple days left and our sale will be over. Good time to save!
Have a Happy New Year!![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Thank you,
Christian
Thank you,
Christian
__________________
