Promaxx small bore LS3 heads...
The following users liked this post:
jayyyw (10-08-2021)
G Atsma (10-10-2021)
Definitely look the same. Flow numbers are fairly close as well. According to each website. They are hefty.
Confirmed that the BTR shaft rocker system DOES NOT work with the Promaxx heads. Rocker spacing is different. Roughly a 1/4" closer together.
Corona (11-18-2021)
wannafbody (11-21-2021)
#32
it'll avg out just like any other aftermarket heads....
383 stroker with Tfs 220 heads or stock bottom end with again Tfs 220 heads. The Promax being Ls3 could use the factory intake. Output would be similar.
13.5 valve angle vs 11 degree and a larger Rectangular port.
Cathedral head test with Mast Ls3 heads ...imagine the same test with a 3.9xx bore
#34
Been looking at using these lately on my ls1 n/A build. Glad I found this thread and read the comments. As I can't get any answers from promaxx. Have sent them messages through their website 3 times over the last 4 weeks.
wanted to know if the exhaust ports where in the standard location. But according to a post above they aren't as they are higher up on the heads.
guess I won't be using them now. Bugger back to the drawing board.
#37
