Why no boosted strokers?
Old Jan 2, 2020 | 09:04 AM
Jimbo1367's Avatar
Originally Posted by DietCoke
X air makes Y power. When you force the air in, the actual CI of the engine isnt much relevant. Smaller CI lets you run smaller bores, shorter strokes, which increases relative piston/rod combo strength due to pin placement and compression height, as well as thicker potential cyl walls.
well said
Old Jan 2, 2020 | 09:09 AM
Jimbo1367's Avatar
Speaking of boosted strokers, What is the safe boost ( 408 with aMaggie) give ya normal K1 or Callies crank/rods with Diamond or Weiscokx boost pistonsAndmatching ?
Old Jan 2, 2020 | 10:07 PM
Mavn's Avatar
"I MAID THEESE"
enough to lift the heads off the block.
I'd say around 35# if you have studs and ls9 gaskets
Old Jan 3, 2020 | 04:45 AM
Jimbo1367's Avatar
so around 12 lbs won’t be too hard on it then?
Old Jan 3, 2020 | 07:59 AM
ddnspider's Avatar
For a given sized turbo, you'll move the power curve down and decrease spool....and increase back pressure the larger you go. Ran a boosted 383, excellent off boost power and spool, went up to 15 psi on 93 pump gas no issues. Doing it over again I would have saved the money on the added cubes and turned the **** on the boost controller lol. Regardless of stroker or not, whether or not it lives comes down to whose tuning it.
