Why no boosted strokers?
Old Dec 30, 2019 | 10:13 PM
Utinator's Avatar
Question Why no boosted strokers?
I don't recall reading a single thread on here about a stroker engine getting boost of any kind. Is there a reason for this?
Building an engine for boost normally requires forged internals. Why not make it a stroker, since the parts cost the same either way? If there's no down side to having a boosted stroker, then why aren't there any boosted/stroked 5.3s? That would be the cheapest engine to build, which is probably why there are tons of boosted 5.3s out there. I just haven't seen any stroked 5.3s. I'm just wondering why that's not a popular choice.
Old Dec 30, 2019 | 10:50 PM
Burken01's Avatar
There are a lot of boosted strokers
Ever heard of a 408? That's been boosted so many times how can you not find one in a search.
The new trend is smaller crank and spinning them higher. So the piston does not come out of the bore and is more stabilized.
Old Dec 31, 2019 | 10:07 AM
Utinator's Avatar
Nope, I've never seen one boosted. I have heard of the 402/408/409s. I just haven't seen one boosted.
Would there be anything wrong with stroking a 5.3, and then boosting it?
Old Dec 31, 2019 | 10:08 AM
AwesomeAuto's Avatar
The importance of cubic inches is greatly reduced with boost. You'll make the same amount of power with a stock stroke or 4" stroke most likely.
Old Dec 31, 2019 | 10:13 AM
DietCoke's Avatar
X air makes Y power. When you force the air in, the actual CI of the engine isnt much relevant. Smaller CI lets you run smaller bores, shorter strokes, which increases relative piston/rod combo strength due to pin placement and compression height, as well as thicker potential cyl walls.
Old Dec 31, 2019 | 11:08 AM
psicko's Avatar
They're everywhere, you are not looking very hard if you cannot find any boosted stroker builds. This one was literally on the 2nd page in the Forced Induction section...
https://ls1tech.com/forums/forced-in...estimates.html
...and this one in the Dyno Results section...
https://ls1tech.com/forums/dynamomet...8-results.html
Old Dec 31, 2019 | 11:14 AM
Utinator's Avatar
That's interesting. I figured with the extra torque that the stroker makes, it would just make that much more hp on boost.
I read a thread on here about the extra energy that a stroker exerts on the rods, pistons, and pins. The piston has to move faster, so there is more inertia generated. I understand why that puts more strain on the components. I just wasn't sure if that's why strokers don't get boosted often.
I'd like to see a before/after dyno chart of a stroker that got boosted. That's where the question of "is it worth it" gets answered.
Old Dec 31, 2019 | 11:15 AM
Utinator's Avatar
I haven't been on that page lately. I'll go check it out. Thanks.
Old Dec 31, 2019 | 11:34 AM
What would you be hoping to see? Whether or not somehow the $2000 rotating assembly made the 1000 HP 4" stroked 5.3 somehow better than the stock stroked 1000 HP 5.3?
Increase the boost pressure to achieve your goals. Using stroke is more expensive and increases wear.
Old Dec 31, 2019 | 11:35 AM
Know It All's Avatar
The trend I've seen is that with all else equal, the larger engine will make the same power at a lower boost pressure, and usually more power with the same or greater boost pressure. This plays a role in the larger picture when you have to design a fuel system and electrical system to fit the needs of your power goals.
The 6.0L blocks seem to have problems with cracking between the cylinders after about 1000whp. Not all do as some people have good luck above that power level and some don't. The 5.3L blocks don't seem to have as many problems since the bores are smaller and therefore, have more cylinder wall thickness. If you don't plan to go above 1000whp, it might be more cost effective to use a stock stroke 6.0L block rather than a forged 5.3L stroker.
Old Dec 31, 2019 | 11:40 AM
Boost pressure is irrelevant. It has very little effect on detonation and engine stress.
Run the shorter stroke. Run more boost. Make the same power.
Old Dec 31, 2019 | 11:48 AM
Darth_V8r's Avatar
Moderator
Gen 3 internal. Search for a thread - building the beast by 98_ws6_M6. Boosted 383. Similar engine by the same owner made 520 but spun a bearing on the dyno. Boosted through a th400 was 985 range. Same heads, both 383. Once you find his thread, pm him. He is a great guy and will share anything he has learned with you
Old Dec 31, 2019 | 12:16 PM
ramairws6's Avatar
440 here 13:1 compression on 300 shot of nitrous. I think this is boosted? No issues here.
Old Dec 31, 2019 | 12:18 PM
It is relevant for the fuel system. The more fuel pressure you need to overcome boost pressure, the less the pump flows, and the harder the electrical system has to work. It may not matter to some, but it is worth considering at least.
Old Dec 31, 2019 | 12:26 PM
Common sense dictates that you don't size your fuel pump so close to the edge that small changes like that will make a catastrophic difference.
There are no available fuel pumps that will lose a large enough % flow with 6 extra PSI of fuel pressure to cause these issues.
An aftermarket regulator would allow you to lower your base pressure enough compared to the stroker that you end up with the same net fuel pressure with increased boost.
It isn't really worth considering.
Old Dec 31, 2019 | 12:52 PM
Tuskyz28's Avatar
Used to see them here and there in GMHTP magazine. Too bad that magazine isnt around around anymore.
Old Dec 31, 2019 | 01:31 PM
sy34010's Avatar
434 with an F1 running 16# of boost makes right at 800 to the wheels. The only issue I had early on was pushing the head, went with 1/2" ARP studs and the problem has gone away
Old Dec 31, 2019 | 01:35 PM
Right out of highschool, I worked at the factory that printed those (along with about 50 other car magazines) before moving into the magazine industry itself.
Its a shame to see so many of them gone now, with a few more having just recently died off.
Source Interlink Media was always pretty good to me.
Old Dec 31, 2019 | 02:15 PM
Tuskyz28's Avatar
That would have been a cool job. I miss those magazines. I had a subscription to them and a issue i really liked I'll go get from Barnes and Noble.
Old Jan 1, 2020 | 10:42 PM
Utinator's Avatar
Yeah, I don't plan on going anywhere near 1000whp. My 4L80 is good for 750 whp, so I don't want to go past that. I figured I would need about 550-600 whp to run 10's in the 1/4 mile. I'd be happy with that. I'm not sure if I could do that with a NA stroker or not. An NA stroker would be cheaper than a Pro Charger kit, but the Pro Charger would give me more room to grow if needed. I want to keep my car daily drive-able for now, so I don't want any extreme build.
