LS7 Solid Roller Build and 200 mph Mazdas
Old 01-18-2024, 06:39 AM
  #61
Ryans99ls1's Avatar
Originally Posted by spanks13
Thanks for the heads up. When I bought them there really wasn't much info floating around on them. I'm starting to see a few reports of that. At least it should show up in lash adjustments.
What's interesting is the T&D's on my dad's big block have pressurized oil feeding the rocker trunion through the pushrod cup. These don't have any oiling ports. I bet if it had better oiling the needle bearings would be fine.
The one i know of that had it happen very early on with super low mileage. Seems to be more instantaneous than self declaring, but if you are going to be checking lash a lot, your choice!
Old 03-07-2024, 04:46 PM
  #62
spanks13's Avatar
Only took 6 years, but we made some noise yesterday! I'll make a dyno results thread. Don't mind the smoke - leaking valvecover after adjusting the valves.
Here are the dyno results
https://ls1tech.com/forums/dynamomet...l#post20546162
The following 5 users liked this post by spanks13:
Bob570 (03-07-2024), gnx7 (03-11-2024), jayyyw (03-07-2024), NAVYBLUE210 (03-07-2024), Ryans99ls1 (03-08-2024)
Old 03-07-2024, 07:20 PM
  #63
Bob570's Avatar
Wow, it starts to sound glorious around 6800 on up!
The following users liked this post:
spanks13 (03-07-2024)
Quick Reply: LS7 Solid Roller Build and 200 mph Mazdas
