3.750 stroke crank?
Dont treat them like a gen0/1/2 small block.
K1 3.9” stroke crank offset ground for 3.8” stroke and 2.00” rod journals.
Eagle 6.200” rod with 2.1” big end and spacer bearing for the 2.00” rod journals.
Wiseco 4.130” bore piston for a 4” stroke and have the machine shop cut the deck to make up the difference.
Why do the above instead of just starting with a 3.75 crank? Are some of the recommendations for improved stability? Cheaper to do? it seems in principle you agree with the approach the OP is considering, but have a different way to get there?
Don't go backwards with a big bore...you guys are correct, thinking about it....big bore wins but damn making a 4x vs a 427+ =😢
We have worked with a few guys to give them domed piston in xxx bore for both cid and max bore class rules and they had great luck.
You dont have to push the envelope to make the best power. In that aspect reliability is also a big deal. Saving cost and maybe only being a few points behind will pay off in the long run. Avg points mean alot more than winning 1 or 2 races and being broke down the rest or the costs eating your butt up.
Optimization of other parts would likely make as much if not more difference there
