Question about an LSA oil pan
So if the engine is going to have the high flow pump and DOD/AFM and VVT operational, you probably want to use a pan that has a bypass valve. Otherwise you can use any pan you want.
Thanks for super detailed explanation!! I told him to jump on here and start up a build thread, I know he's on Nasty z28 and I believe a pro touring one as well.
And LilJayV10 you go that right. The DS stuff is pure sexyness. He made up some wooden wheels to roll the sub-frame under the car and square it up to keep going with mock up and it's all just a work of art.
