Bearing clearance
Old Mar 5, 2020 | 07:17 PM
Last 1's Avatar
Default Bearing clearance
Putting my new engine together and setting it up 250 shot of nitrous . How much clearance do I need to run on rod. bearing .0025? I Will be running king bearing pmax all ready bought the standard size and .001+ thanks for your input. I will be running a Wet sump oil system with a accusump
Old Mar 5, 2020 | 07:21 PM
.0025” is fine for rods. What are you doing for mains? Al block or iron?
Old Mar 5, 2020 | 08:06 PM
Last 1's Avatar
Main are from .002 to .0023 new RHS block alumnium block 450 cid Just finished the last piece of the puzzle order a custom cam from mike jones
Old Mar 5, 2020 | 09:04 PM
Sounds like a fun build. What’s it going in? What heads? Tell us more! Pictures are even better!
Old Mar 6, 2020 | 05:38 PM
Last 1's Avatar
Build List
RHS block 4.165 bore
king pmax bearings
K1 crank 4.125 stroke
Wiseco-11 inverted domes .009 in the hole Will be using a .030 head gasket =11.73 compression/ 93 octane
Lunati pro series I beams 6.125
ati 10% UD damper
melling oil pump + accusump
Trick Flow 260 ls7 heads with Ferrea hollow stem valves 2.200 in /1.615ex
crower shaft system 1.8 with needle bearing
/ steward solid lifters. 750 wheels with needle bearing
mike jones custom cam
Pac 1237x springs and PAC tool steel retainers
MSD intake
balancing by Whites Proformance @ Kingsport Tn
looking to make 700 hp @
the flywheel
if I don’t this’s bottle will take care of it /the dyno run is on my ls2 Thru a 4.10 on a 150 shot on a conservative tune 8 degrees of timing pulled
Old Mar 7, 2020 | 06:44 AM
Last 1's Avatar
Anybody else running 250 shot ? What your clearance on your mains and rod all input appreciated.
