Compstar vs lunati voodoo crank
Im in the market for a 4.00 stroke crank. Narrowed my choices down to compstar with the center counter weights or the lunati voodoo. Anybody got a reason to choose one over the other. I would usually go lunati but the ccw make me think the callies might be better. Opinions.
Now that is a seriously out of the box idea. Lol. But that would only give me one center counter weight. Maybe cut the center out of the callies and weld it into the lunati would be better. What do you think.
Rated to 800-900 hp and I'm sure someone has taken them beyond. Callies crank and rods in the 427 but I wouldn't be afraid to run any of them upwards to 900 and this includes a K1 an Eagle or Scat cranks
Gonna be a turbo set up. 1000whp is likely but will only turn it up as needed to run a mid to low 9 in a 3800 pound car with an ok suspension. Best i have run so far is a 1.63 60ft. Made a goal of sub 9.50 quarter on a 17 inch drag radial but like always i probably wont stop turning the boost up till i kill something or just cant go faster without spinning.
It's one of the fastest trucks in America period. He always in the top 3 fastest at truck wars years yearly.
My tuner has a LSX 427 turbo cateye truck that run deep 5s in the 1/8 mile. Anyway he had a K1 crank flex on him.... he running a callies crank now. Crank hasn't failed him yet.
You might want to get the Callies Dragon Slayer or the Magnum Crank for that power level. The magnum is a gun drilled Dragon Slayer. They are both forged and machined here in the USA. You might want to get the Ultra rods too. You will crank the power up. Everyone does. When you do, you will have piece of mind. At the end of the day though, the life of your parts is directly reflected by the quality of the job being done putting it together and tuning. I have seen some compstar stuff not handle 1000Hp then I also have a friend with a compstar crank and rods that sprays his to 1300Hp and it has lived for 2 seasons and hasn't refreshed it and doesn't plan to till the end of this season, which I think is crazy but he wants to see how long it lasts. His money I guess. We run the Dragon Slayer and Ultra H-beam rods. Every time we freshin it up, all the bearings still look like we just installed them and we spray quite a bit too. We both use the same engine builder and Dart blocks. Just my .02
The following users liked this post:
01CamaroSSTx (04-11-2020)
joyridin' (04-12-2020)
Get a plan together and spend as much as you can afford on a short block. If your going big on turbocharging then you start looking at what your going to be needing for a foundation and what parts need to go into it and on top of it..
