Are Gen 4 5.3 blocks the same as LS2 minus bore?
Old Apr 14, 2020 | 01:49 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Are Gen 4 5.3 blocks the same as LS2 minus bore?
Are the aluminum Gen 4 5.3L blocks (LH6, LH8, LH9, LC9) the same as an LS2 block, just with a smaller bore? Basically, can the Gen 4 5.3L blocks be bored to 4" and become an LS2? I know some have DoD and AFM, but those features are not part of the block, right?
Sorry if that is a stupid question, just curious since I am thinking of having my LS1 machined for a stroker.
Old Apr 15, 2020 | 12:06 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
No, the 5.3 block is different. Solid main bearing bulkheads, no breather holes. Max. over bore on the 5.3 3.897" same as the 5.7.
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Apr 15, 2020 | 09:33 PM
64post's Avatar
It weighs more than an LS1, 118 to 104lbs fwiw.
Old Apr 15, 2020 | 11:01 PM
Likely because of the solid main bulkheads, among other things
Old Apr 15, 2020 | 11:08 PM
LS1TECH Sponsor
Default Gen IV block weight
GM raised the floor of the water jacket on the Gen IV blocks. There is more aluminum in the block which is why they weight more.
Unfortunately they went with shorter head bolts as well which don't tie the block together as well as on the Gen III. Ford did the same thing on the Coyote blocks but has since gone back to the long bolts.
QUOTE=G Atsma;20235184]Likely because of the solid main bulkheads, among other things[/QUOTE]
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Old May 23, 2020 | 09:22 PM
fauxgs's Avatar
I'm building a supercharged Gen IV. It started as a 5.3 VVT/DOD. When touring a nationally known speed center it was discussed. He then showed me two pallets of new GM 5.3 blocks they just received; they are the building blocks (no pun intended) of most of their HP engines.
Old May 28, 2020 | 05:39 PM
01CamaroSSTx's Avatar
If I was going to spend a bunch of money to re-sleeve a Gen 4 block it would be an LS3 block.
By Brett Foote | 2026-06-04 05:00:17
