LH6 Advice
Edit...it’s a crossover engine. I’m wrong.
Yep, by the way things "should" be. My 05 LH6 is a bastard lol. I thought I had an L33 until I realized it had 799 heads, front cover mounted crank sensor, and 24x.
05-06 are 24x, 07-09 are 58x, according to the above source
In my personal opinion, delete the AFM. Summit has a nice line of off the shelf LS cams and are pretty knowledgeable about helping you decide which one to go with based off your needs. IIRC the 06/07 Envoy denalis had the E40 PCM which seems to be one of the preferred options for tuning.
Getting 75 horsepower isn't a big deal with just a cam, but you have to realize that it isn't going to idle the same or get the same fuel economy.
There have been probably 100+ dyno comparisons for cams in a 5.3, it should be fairly easy to find them.
Definitely delete the AFM.
According to summits LS identification tool, the L33 shouldn't have 799 heads. Is it mistaken? I keep finding conflicting information. My engine came out of a 2005 GMC Envoy Denali 2wd standard wheelbase. Which by everything GM says it should be an L33.
