Help with head casting to run
Old May 29, 2020 | 02:47 PM
SLOW5777's Avatar
Default Help with head casting to run
Hi All, First time caller long time listener or something like that. I have a 6.2 L86 I plan on putting in my 2011 avalanche. I have a ls9 cam, and yellow ls2 valve springs on the shelf. My decision becomes what heads do I run. the factory 823 or a set of 243 that I also have on the shelf. Plan on long tubes when I swap it in, and already have HPtuners on the truck, so tuning wont be a problem. I have everything to go either way with the heads just cant decide what casting I want to go with. It is my daily, but I beat the thing daily. I know the 243 makes a little more power under 4k but I am cheap and don't want to buy head gaskets and head bolts/studs lol. just don't know how much performance I will loose under 4k. Truck has 6l80 with leveling kit and CAI. No plans on boost in future just looking to have a little more kick in the ***. I can appreciate everyone's opinion because it might be an angle I have never looked at before so please give me your 2 cents. THANKS
Old May 29, 2020 | 04:20 PM
If you want more kick, unload that LS9 cam. It does you no favors under 5k RPM. No heads will improve anything until you get a cam that can use them right.
Old May 29, 2020 | 05:49 PM
01CamaroSSTx's Avatar
https://cammotion.com/camshafts/6-2-...212-220-117-5/
Old May 29, 2020 | 06:55 PM
This cam, compared to the LS9 cam, will kick your engine into next year.
Old May 29, 2020 | 07:33 PM
old motorhead's Avatar
With stock static CR at 11.5 on your engine, I wouldn't fool with the 243 heads. You'd get higher static (which you don't need) and less flow. Personally, I'd go with something like a 218/226 116 with enough advance to get you to around a 8.2 DCR. Not too big to be a drag around town, but big enough to provide a nice bump in power. Agree with the above about the LS9 cam. The only thing good about it is the price. It doesn't fit your program.
Old May 30, 2020 | 01:39 AM
bortous's Avatar
After my experience stick with the 243 heads and give them a good cnc port job.
These will give you more usuable power everywhere
especially in a truck that needs the extra punch in the low and mid range rpms. You will also have better throttle response and under the curve power which makes for a fun and fast street vehicle.
