Max recommended stroke?
1) Is it always necessary to have a forged crankshaft? Let's say you just wanted to increase CID on a daily driver, but not spend a fortune. Would you really need a forged crank for a modest HP goal? By modest, I'm thinking 400-500hp at the crank. I figured the torque on a stroker would be much higher than the stock stroke in the same engine.
2) Would a stroke longer than 4" cause issues? I found a 4.1" crankshaft on Summit's website. It was non-forged, and much cheaper then the 4" forged cranks. The 4.1" stroke could offer some appealing CIDs. Here's some examples I came up with based on a CID calculator...(392 CID from a bored 4.8 or 5.3, 427 CID from a honed 6.2)
3) Obviously, boost will increase HP more than any stroker combination. Would a cheap junkyard 4.8/5.3 be worth boring/stroking?
1.) For 400-500HP just keep your stock crank. You don't need a bigger cubic inch motor to get to that HP goal.
2.) You will run into clearance issues with cranks bigger that 4" and you're going to bring the piston out of the sleeve too far down (Engine won't live long)
What brand makes a none forged 4.100" stroke crank? How are you calculating your cubic inches?
3.) You can stroke it but for the goal you have you don't need boost nor a stroker to achieve 400-500hp
Also some of the cast crank stuff is horrible balance wiae and ends up costing like $450 to balance. At that point the cast crank is within $250 or so of the coat of a forged crank.
The new GM 6.6 liter gas engine has a 3.858 stroke crank
I've not seen pricing on that crank. It might be more reasonable in cost. I think its possible this Gen V 58x crank may work in earlier LS engines.
Fwiw both my strokers have Callies CompStar cranks, both are 4 inch and are problem free.
I was thinking that there are a lot of really cheap 4.8s and 5.3s. If you bore an iron 4.8/5.3 out to 3.902 with a 4.1" crank, you get 392 CID. I doubt many people use the stock 4.8 crank in rebuilds. If you are replacing the 4.8 crank, you might as well go way bigger. The 4.1" crank cost about the same as a 3.622" crank. It seems that the stock sleeves might be a bigger issue though.
I have found a couple 6.2s for cheap, but they needed to be re-sleeved due to DoD lifter failure. I'm not sure what a re-sleeve job costs, but that would be a prime opportunity to install longer sleeves. With longer sleeves, the 4.1" crank might be do-able, as long as the journals aren't an issue. You would need about a 4.072" bore with the 4.1" stroke to achieve a 427 CID.
The new 6.6L crank would also make some interesting builds. I haven't seen one for sale yet. I'm sure there are a lot of people waiting for one to become available.
I just sold the 5.3L “truck” engine I built. Now, I’m looking for my next engine to build. I would love to have a 427, but the block/part options are limited with stock blocks. The 6.2L honed to 4.070 with a 4.1” stroke would be close enough. Wisco makes pistons for this. I also saw a 6.0L bored to 4.070 with a 4.1” crank for sale. I’m just not sure about the reliability.
That is very interesting, but also very expensive. That's why I don't want to order from a shop. I was planning on building a complete running stroker engine for around $5-$6k.If it costs more than that, then it would be cheaper to just buy a turbo kit.
I don't see how Wisco can make a piston that will work with a 4.250" stroke in a stock 6.2L block. That seems a bit extreme. It might be possible with an LS7 block, but I don't think I would try it with any other stock block. The 4.1" stroke might be more reasonable, but that's still a lot.
I suggest getting a parts list for a build and adding up the cost of the parts, machine work etc and see if you can build a running stroker on paper for less than $6,000
Best cost per hp is probably a junkyard motor with a fat shot of NOS or forced induction because NA hp tends to be expensive.
@KCS one of our moderators worked with Erik, HPR & Wisco to develop the custom pistons required for the 4.25 stroke LS build I believe KCS even used this super trick piston in a 6.0 iron block successfully that has the shortest cylinder length of all LS engines.
I would definitely be using a "junkyard" motor. I don't see the point in buying a new crate motor. I have found bare 6.2L blocks for around $650 or less. I can get heads for about $600-800. The rotating assembly is about $2000. I might need a machine shop to mill the heads, and maybe balance the rotating assembly if it's not already balanced. That's less than $500. That's about all the machine work I would need. On my 5.3L rebuild, I only used a machine shop to mill and flow test the heads. As long as I get a good bare block, I shouldn't need any other machine work. I already have a parts list for a complete Gen-4 engine rebuild. The stroker I built on paper comes out to roughly $5000-$6000 for everything. There are a few variables that I can't account for right now. That's why it's such a large price range.
With any used block for a stroker build I'd be concerned with making sure the ring seal is optimized and cylinder holes as perfect as possible due to the nature of the beast etc. Definitely at least a clean up hone is almost for sure is needed etc for a used block.
Good luck.
