LS7 head spring pocket depth cutting
what if my spring height was too tall and i had to cut 0.050" extra depth into the spring pocket
my head guy was nervous about it but as of right now he is doing it may have already done it
this is a huge 650 lift solid roller cam w like 450lbs open spring force the pressure in that spring seat must be unreal and aluminum has very **** fatigue life so if it bends at all even minor flexing over a short time thats millions of fatigue cycles
how thick are ls7 heads in that area?
did i just ruin a set if max effort cnc ported ls7 cylinder heads?
please tell me its fine and gm put a ton if extra material there
lets assume its Gen V for giggles (unless a mod wants to move my thread for me)
whats the alloy difference between Gen IV and V? crap is there another sub forum when asking a Gen IV / Gev V agnostic question? Again maybe a mod can help
i also wonder if its the same casting methods, i think the V is DI so it may not only be stronger and heat treated differently but also a thicker section so if this is a Gen V, how much if any can i increase seat depth before elastic strains get too high and i have a fatigue fracture? assuming a 450 lb open seat force at 8000 rpm w a solid titanium valve?
ive been told by some racers they have epoxied that area when they cut too deep and crazy enough it survives many race seasons
just looking for some wisdom many thanks Jeff Check
That same 450 spring pressure pushing down on the deck is pushing up on the valve tip. The valve stem will fail before the head just on pure mass and surface area.
I know a guy who ended up over 600 lbs open pressure and the tip flew off the valve. Heads were fine.
All that said I would do what Todd said above. But not out of fear. It is just cheaper and easier to swap springs than machine the heads.
Yes, I had to run shims to get them setup at the correct height/coil bind.
I need to put a bigger spring. Around 400 in seat and 800 rate. Cam is a 278 300 with .780 lift
