Cam recommendation to limit torque
I am using an L33 in a swap in front of a relatively weak transmission. I would like to limit torque to 650 ft*lbs but still make 1000hp, so I am looking for a cam and that will flow well out to 8k+ in a turbo application. Can this be done with stock 799 heads and an LS4 intake manifold? I am going to start with stock internals, so ideally the cam will work with OEM flat top pistons without valve interference.
Horsepower is a calculation of torque vs RPM.
Lower the torque, HP goes down, unless you rev it a lot higher.
No cam will cut torque and keep the same HP.
The following users liked this post:
KW Baraka (07-17-2020)
Moderator
Received 1,838 Likes
You'll need one helluva valvetrain set up. I highly recommend solids, top shelf springs, and top shelf rockers. my recommendation assuming a solid cam would be along the lines of 238/256-116-2 (that's minus two, i.e. retarded cam). That cam will support the RPM and should not build too much torque. Back of the napkin math, and I know there are pros out there who will either do a better job in general or outright laugh at that spec.
The rest will depend on how well your turbo(s) spool, etc.
Personally, i think it will be easier to get a beefier transmission, but to each their own.
Cool, ok thanks. What is generally the rpm limit for a hydraulic lifter setup? The tranny is very expensive to upgrade so I am hoping to work around it.
Moderator
But getting to the other parts -- LS4 intake stinks. stock 799 heads, i mean, at least do a premim vlave job. And you'll need premium valves to spin that fast. And then there's all the nuance details of building to spin 8K on a regular basis. My point is that I do recognize how expensive a transmission build is. But you might be surprised after pricing everything out, it's cheaper than setting yourself up for 8000 rpm. You take those johnson lifters, custom pushrods, high end rockers, high end springs, valve job to go with that. You'd be amazed where you are after pricing that out.
Do what you want. I'm just trying to make sure you know how deep the rabbithole goes...
