2010 LS3 Camaro Engine issue
Old Jul 21, 2020 | 04:57 PM
Eddie Sipes's Avatar
Default 2010 LS3 Camaro Engine issue
I was driving on the highway, noticed what felt like a misfire, along with a flashing check engine light, I pulled off the highway which resulted in the worst hesitation ever, i turned the car off before it died. When I tried to start it again it wouldn't even crank over. The mechanic tried rotating it ny hand and it wouldnt go either way. I know its something bad, just trying to get ahead of what parts ill need (besides the obvious)
Old Jul 21, 2020 | 05:13 PM
Nobody will have any idea until it is torn down.
Old Jul 21, 2020 | 05:17 PM
I figured, was just wondering if anyone could point me in the direction of who makes the best rotating assemblies. I might as well beef it up if I have to rip it apart and rebuild it
Old Jul 21, 2020 | 05:24 PM
Darth_V8r's Avatar
Moderator
If it's mostly stock, it sounds like you'll be swapping in a used engine. To confirm the engine is gone, cut open the oil filter. Probably loaded with glitter. Hell might even see it on the dipstick.
Old Jul 21, 2020 | 05:29 PM
No swapping. Just rebuilding. It didn't blow up. I'm confident I can save what I have.
Old Jul 21, 2020 | 07:40 PM
Not to rain on your parade, but you will only know that upon teardown. Not all engine failures go out in spectacular fashion.
