6.0 build help
Old Jul 23, 2020 | 05:45 AM
camarozz383's Avatar
Default 6.0 build help
Hey guys, just picked up a 6.0, it's been bored 40 over, new flat top pistons, I have Ls3 heads to go on it, getting rid of the dod, what cam sprocket do I need to do the swap, also is there any builds that make 500hp with this set up? Or how much power can I make N/A thanks
Old Jul 23, 2020 | 08:31 AM
Labsforever's Avatar
Cam sprocket will depend on if is a 24x or 58x crank wheel. 500hp with a 6.0 is easy with square port heads. How much power can be made is usually determined by how much money you have to throw at it and any self imposed restrictions such as stock hood or restrictive exhaust
Old Jul 23, 2020 | 10:24 AM
If it had DOD it is a Gen IV, which means a 58x reluctor.
Old Jul 23, 2020 | 11:16 AM
I agree but I dislike assuming when I don’t have anything in front of me and we have few details
Old Jul 23, 2020 | 12:16 PM
I based my post on the fact that there are NO 24x 6.0's that came with DOD, as opposed to some 5.3's that did (LH6). The only 24x Gen IV 6.0 was the early LS2, which did not have DOD.
This 6.0 IS 58x for the reasons above.
Old Jul 23, 2020 | 12:23 PM
DavidBoren's Avatar
LS3 heads and intake on a 40-over 6.0L... 500hp shouldn't be too difficult.
Spend a little bit on some good lifters and springs, get a cam spec'ed for your combination and goals.
Old Jul 23, 2020 | 02:06 PM
engine has been rebuilt. Was original crank reused? We don’t know. This back and forth is of no use to the OP I’m done
Old Jul 23, 2020 | 03:29 PM
JRFed's Avatar
OP, do you have specs on the pistons you selected?
Old Jul 23, 2020 | 04:20 PM
He stated he is getting rid of DOD. This means it still had DOD, and for that reason the reluctors had not been changed. Use a little logic here.
Old Jul 23, 2020 | 08:11 PM
01CamaroSSTx's Avatar
You will need to go with a 3 bolt cam and sprocket with new lifters, lifter trays, valley cover and possibly push rods. Check out BTR racing as I believe he as many others have cam kits for those getting away from DOD setups.
Old Jul 24, 2020 | 05:03 AM
Default 58 too
58 tooth, stock crank, I will be using new lifters and Push rods, springs, not looking to race, just a strong little engine for my s10, thnaks
Old Jul 24, 2020 | 06:42 AM
You need a 4X cam sprocket with the 58 tooth reluctor. I use the RollMaster CS1190 for my 58 tooth stuff. Comes with the best timing chain in the industry, billet timing gears, and a billet oil pump drive. WS6Store has the best price on this set btw.
Old Jul 24, 2020 | 08:50 AM
Ditto/ good source for most of what you will need to get your engine together
Old Jul 24, 2020 | 11:43 AM
Thanks for the info!
Old Jul 28, 2020 | 04:23 AM
That's the pistons
Old Sep 10, 2020 | 05:31 PM
It's gen IV
