Understanding my engine, help.
Old Jul 25, 2020 | 08:49 AM
AnnivSS's Avatar
Default Understanding my engine, help.
Good Morning all. So it seems I am finding a bit of conflicting information on the interwebs but it seems as if the aluminum 5.3L I pulled from my parents wrecked 05 GMC Envoy Denali (VIN M) is an LH6. However everything I can find says that should be an AFM engine. That vehicle for 100% fact did not have AFM. I did find a few blurbs (nothing Id take as a statement of fact) that they "had" AFM in 05 but it wasn't wired up. Am I still going to need an AFM delete kit for this engine?
Old Jul 25, 2020 | 09:22 AM
Bspeck82's Avatar
https://media.gm.com/dam/Media/docum...2005Envoy.html
Old Jul 25, 2020 | 09:45 AM
AnnivSS's Avatar
Ok so the short wheelbase models did not have AFM. Awesome. Thank you.
Old Jul 25, 2020 | 10:59 AM
It wasn't activated on the SWB models. All LH6's had the capability. So you still might need the DOD delete kit.
Old Jul 25, 2020 | 11:26 AM
AnnivSS's Avatar
So I suppose at this point the only way to be sure if to pop the valve covers off and check to see if it has the 4 oddball rockers?
Old Jul 25, 2020 | 12:20 PM
Rockers are all the same. 2 different lifters on AFM/DOD engines.
Old Jul 25, 2020 | 01:10 PM
64post's Avatar
If it has a valve body for a Valley cover or oil towers in the valley that are drilled, you probably need some kind of delete.
Old Jul 25, 2020 | 01:16 PM
AnnivSS's Avatar
I havent removed the valley cover yet but I seem to remember the top side of it looking the same as the one I pulled off my LM7.
Old Aug 1, 2020 | 11:33 PM
64post's Avatar
You would know by looking at the top of the Valley cover, it’s not smooth but looks like a transmission valve body.
