CCW crank vs non ccw
From what I'm hearing of you are running a stroker engine you will have a significant improvement in the life of the main bearings with a CCW crank vs one without the extra weights. The engine I'm building if for a daily so it will have a lot of miles put on it. Is this a highly recommended part or only Important if I am turning high rpm.
CCW cranks are designed for high rpm applications to retain stability and help bearings live. For a daily you don’t need one.
The following users liked this post:
Double06 (07-29-2020)
