L33 or LC9
Old Aug 17, 2020 | 07:37 AM
  #41
old motorhead's Avatar
I have an L33 in my work truck. Supercharger went **** up, so now it's n/a. It has mildly ported 243 heads, stock truck intake manifold, long tubes, and a 218/230 118 blower cam. It made 331/320 on a dynojet. That's through a 4L80 trans.
Old Aug 22, 2020 | 11:18 AM
  #42
LS Grasshopper's Avatar
Thanks again everyone.
G Atsma..... I had read somewhere 15% was just a general "rule of thumb" for manual transmission cars when converting fwhp to rwhp. 20% was the same general rule for automatics. I'm sure it's much more technical than that though.
I do have another couple of questions to ask but if you all think it would be better served in the Gen III forums I can ask over there instead.
1) I am going to move the engine as far back as I comfortably can without having to do any "surgery" on the firewall. Maybe a little "massaging" but no cutting and welding. I think the L33 has at least one sensor (crank position sensor?) mounted on the rear of the engine. Is this going to cause any problems? Can it be relocated? Would a true Gen IV 5.3 (LC9) be a better option for a tight rearward fitment? The T-56 Magnum has multiple shifter locations so this may not be an issue, but the farther back the better for weight. There may be a shifter location that allows for a very rearward fitment and still have access to anything on the rear of the engine that I might need to get to. The new combination will be about 200 lbs heavier than what is coming out. I'm going to have to go with a custom driveshaft anyhow so no worries about transmission to rear end length.
2) With Jr. College and all (not to mention a new "family dynamic" ) I'm not so much on a "limited budget" but a limited time:money ratio if that makes any sense. I'm not going to go cheap just to get done, it's just going to take longer to save for quality parts. Two things dad taught me......Plan the work and work the plan and if you can't afford to do it right the first time, how can you afford to do it right the second time? So, that being said, my head choice is the 243/799 and a good mid range cam. (wish I could find something like the "Triple 12" I've been reading about). But let's say (for S&G's) that I want to go with a small turbo build 3-4 years after I get it on the road. Something, that I can do myself as my skills get better. Am I better off keeping the 243/799 heads and adding a turbo years later, or is the compression ratio too high with those heads? (And what about turbo and flat-top pistons? Good or bad?) Or should I go with a lower compression head (706/862) right up front and and enjoy them N/A and be "ready" for a turbo upgrade if I decide years later that that's what I want. I know I asked something similar to this and have taken that into consideration and I am hoping that I can keep the 799's and either add a turbo to it or that the cost of changing heads at a later date is minimal. I don't know (because I don't have the practical experience yet) if even though the 799's may be less money up front (comes with the long block purchase), it may be more money in the long run run because I will have to buy a second set of heads if I end up changing my mind later.
If any of you don't understand, this is the kind of mental frustration you have to deal with when you have OCD! It can be draining. I'm not looking for a definite answer from anyone, just solid opinions that I can weigh against each other to try and make as an informed decision as I can. Ultimately it's up to me to make the final plans and again I'm just about there. I like reading the build threads on here and using that information to help make decisions. Sometimes it becomes information overload, but they have been helpful as have all of you.
Thank you again for your patience.
Old Aug 22, 2020 | 02:28 PM
  #43
For mild boost (less than 14ish psi), 10:1 is really good. No sense in going lower. Find you a cam that will play nice n/a and with a little turbo boost. One of the cam guru's can set you up.
Old Dec 19, 2022 | 10:18 PM
  #44
Vic Nalbandian's Avatar
Default L33 vs LC9
Originally Posted by LS Grasshopper
Hello everyone.
I posted a similar thread in the Newbie Tech section and it was a great help. So much good information and advice. I had decided on (and am still 99% sure) I want to do an L33 build to go into my Triumph TR7 but they are getting harder to find. I am seeing the LC9's though and wanted some opinions.
Some quick details on the TR7.....
Total weight after engine and trans swap approximately 2600 lbs.
Tremec T-56 Magnum (probably wide ratio)
Ford 8.8 (easiest to swap into a TR7) with either a 3.27 or 3.31 gear
195/60/15 or 205/50/16 (basically a 24" tire)
I know the L33 didn't have AFM or VVT so that is a plus. Simpler system definitely. But again, it seem the L33 is getting harder to find. The LC9 though seems easier to find. I would definitely being getting rid of the AFM, but the VVT seems like something I might want to keep if I were to go the LC9 route. About the only thing I would be "upgrading" is the cam. To what I have no idea and that would be a discussion I would have to have with the knowledge base here and at a shop. I know the VVT would limit the cam choices, but I'm not looking for a high hp build. 325'ish rwhp is plenty. From what little I have read (and understand) a better VVT cam (over the stock one) would give a broader power band "under the curve". I'm planning on a highway cruiser with plenty of light to light get up and go. More available torque for low rpm cruising and better high rpm "oomph". I'm still working my way through the threads about the 58x reluctor wheel and still haven't entirely grasped the concept. I understand that VVT isn't doable with a 24x ?
So, with all that being said, what are your opinions on using an LC9 rather than the L33. I'm not asking you to talk me out of the L33, but help me understand the pro's and con's of the two. Again I still prefer going the L33 route and am in no real hurry, but It might be easier, instead of searching for that needle in the haystack to just use one of the pitchforks that are laying nearby.
Again, I haven't abandoned my other post int he Newbie Tech section or the wealth of information that was offered and greatly appreciated there. I just thought this question would be better asked here. Just tryinjg to explore all my options and lay out a solid plan before going out and start sourcing parts.
Thanks again to everyone who has led me this far.
both 5.3L engines are very similar, chances are the LC9 will have lower mileage. Otherwise delete the DOD and as far as the VVT… if you’re running the factory ECM it’s doable but if you’re planning on using a aftermarket ECM. Most likely it won’t support VVT. Best thing is also deleting the VVT and install a BTR Truck Norris cam. You’re going to have over 450 hp at the crankshaft without losing bottom end torque . The 58 tooth reluctor wheel is just a more accurate measurement for ignition timing. You will need a 2007 or newer factory ECM for the 58 tooth wheel. The crank sensor is above the starter. If the sensor is gray, it’s a 58 tooth sensor. If the sensor is black, it’s the 24 tooth system. Aftermarket systems like Holley Terminator X max are system specific but available.
