LS3 Won’t turn over.
Old Aug 1, 2020 | 05:02 PM
01CamaroSSTx's Avatar
Originally Posted by Chris1895
Ok I think I found the problem. The. Bite size on the head gaskets that I put on new is slightly smaller than the bore of the original head gasket.
What do you all recommend for head gaskets?
Sucks you had to go back through everything and you won't make that mistake again ...I'd just replace it with the stock MLS gaskets and maybe SD will send you the correct ones at no extra cost.
Cometic MLS 4.08 bore .051 thickness
